Author Topic: Custom Monitor Bezel  (Read 2332 times)
Woodshop Flunky
« on: June 23, 2011, 01:48:56 pm »
I'm going to go way out here...
Does anyone have any experience with vacuum forming?  I have several sheets of ABS plastic with haircell texture on one side.  I would like to produce a monitor bezel for the CRT PC monitor I decased.
I've read about it, and I have a process in my head that I think will work.  However, it certainly seems like a LOT to bite off.
Anyone tackle something like this before?
mrclean
    • Guscade
Re: Custom Monitor Bezel
« Reply #1 on: June 23, 2011, 02:46:35 pm »
phineas foo on the KLOV forums does this : http://forums.arcade-museum.com/showthread.php?t=151068, I would contact him.
2,370,650 Gun.Smoke
« Reply #2 on: June 23, 2011, 02:48:51 pm »
Or you could just do this:
2 dolla bezel
Woodshop Flunky
« Reply #3 on: June 23, 2011, 03:19:20 pm »
I think I've run across this guy before, but at this point in my build, I don't think I can justify the expense (if I can do something myself).
2 dolla bezel
Thanks.  If the ABS doesn't pan out... I'll likely end up with something like this. :)
