Author Topic: Some U360 Questions  (Read 3267 times)
Rando
Some U360 Questions
« on: June 22, 2011, 09:30:09 am »
Hey all,
I recently installed some Ultrastick 360's, and initial response is good, but I have some questions.  Current configuration has joysticks undermounted with dustwashers on top.  I may top mount them in future, but still see dustwashers on top.
- When I boot up my PC, the joysticks are found, but they don't move anything. I have to start my UltriMap software and do a quick download to the stick (to designate 4-way vs 8-way vs analog, etc.) before stick will respond.  It's a fine and quick fix, but not user friendly, what is my issue?  Sticks are connected via USB and both plugged into a USB sharing device, and both have unique identifiers setup.
- What is the best mode to leave the sticks in for most 80's/90's games?  4-way? 8-way? Analog?  Currently I'm leaving in analog and changing to some other settings depending on game to test things out.  But asking for best recommendations.
- During the more intense joystick games (ex: Robotron) the balls on top will loosen and start to unscrew.  I don't want to glue them as I will need to remove them in future.  I don't want to grab sticks with pliers and tighten the balls because I risk damaging the rods.  Ideas to keep it tight?
I think I had another question but of course can't remember it now.  Most curious about 1st question above.  Thanks!
DrChek
  • Last login:November 12, 2025, 11:56:43 pm
Re: Some U360 Questions
« Reply #1 on: June 22, 2011, 10:14:50 am »
If you remove the circuit board and magnet on the bottom of the stick there is a flat head slot on the bottom of the shaft. Hold the shaft still with a screw driver in the slot while you tighten the ball top. You should be able to get it tight enough where it won't loosen under normal play.
Rando
« Reply #2 on: June 22, 2011, 10:22:24 am »
Awesome,
Thanks.
Is it as easy as you make it sound or is there a "WATCH OUT!" type of moment where some spring will try to fling my magnet across the room as soon as I remove the board?  Trying to cover all bases!  ;D
DrChek
« Reply #3 on: June 22, 2011, 10:27:25 am »
Awesome,
Thanks.
No springs will be released if you only take off the board and magnet.
As far as loading maps, you could always place a shortcut to the command line ultramap utility in the startup folder to load a default map whenever windows starts. A better option would be to use a frontend that supports ultramap loading for each particular game. I recommend Mala + Utramapper plugin. That way 2-way games play 2-way, 4-way play 4-way, etc...
Rando
« Reply #4 on: June 23, 2011, 10:20:48 am »
Thanks much,
I'll reload MALA and look into getting that setup again.  Had it previously then my PC crapped out, so am only using MAMEUI at this point.
Thanks.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: June 25, 2011, 08:45:38 pm »
Make sure Ultramap is set to 'scan for sticks on startup'. Although, I think sometimes USB hubs and the like just get in the way of this.
-Banned-
mgb
  • North East, US
« Reply #6 on: June 25, 2011, 09:34:07 pm »
For the balltop loosening issue, you can also try some Loctite on the shafts threads. just use the light duty one (I think its blue).
Donkey_Kong
    • CNC Machines
« Reply #7 on: June 26, 2011, 10:22:07 pm »
Be careful with the knob frightening techniques. One time I tried pliers on the shaft and fabric as a cushion and still ended up with teeth marks. They are ugly and you can feel em to when playing, annoying.
Rando
« Reply #8 on: June 26, 2011, 10:49:18 pm »
Exactly what I'm trying to avoid, thanks for tips!!!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #9 on: July 04, 2011, 12:56:12 pm »
The bat tops come with little lock washers. Find some of the appropriate size for your balls.
-Banned-
