Author Topic: MacVision Help????  (Read 1521 times)
rmusick
  • Last login:November 12, 2017, 09:15:41 pm
MacVision Help????
« on: June 11, 2011, 01:38:32 pm »
Hey all, I need some help.  I got my MacVision monitor yesterday and began my testing process.  I am having major Interlacing problems and dont know what to do correct it.
Here is my setup:
Dell Computer with Brand new Arcade VGA
J-Pac Running into monitor via, adapter.
I have tried both the J-pac and running the Monitor straight into the AVGA, same problem
I have also flipped the jumber for 75ohm and 1k back and forth, no luck
HELP?????
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
Re: MacVision Help????
« Reply #1 on: June 11, 2011, 02:24:30 pm »
interlace issue
maybe you mean sync?
perhaps a photo of the issue will clear things up for us.
rmusick
« Reply #2 on: June 11, 2011, 02:36:21 pm »
nope syncing is fine.  its like a "Strob or Flicker"  If you flip it to different resolutions under Arcade VGA it goes away, but the screen looks like crap and them Mame wont load properly.
lilshawn
« Reply #3 on: June 11, 2011, 02:40:28 pm »
