Author Topic: What is best FE to run with Tankstick?  (Read 1625 times)
TNVols
  • Last login:June 16, 2011, 08:32:26 pm
« on: June 11, 2011, 09:18:31 am »
Can you weigh in on what the best FE to use with the x arcade tank stick.  I have been having the exit issues with maximus arcade and was wondering if there was another out there that did not have this problem.  I have a P4 with windows XP 32 bit.  Running the latest version on MAMEUI as well.  If rolling back to an older version helps that would not be a problem either.
Thanks for the insight.
madmatt
  • Last login:November 08, 2015, 08:47:54 am
Re: What is best FE to run with Tankstick?
« Reply #1 on: July 26, 2011, 01:09:14 pm »
I too have had this problem with MA.  The best fix is to hook up a cheap usb gamepad to your system and use that
to totally control and exit M.A; I know it's a pain the #$%  :banghead: but it works great.
That's my two pennies.
