Author Topic: U360 shafts with metal CP (?)  (Read 2558 times)
Gray_Area
  • -Banned-
  • -Banned-
« on: June 08, 2011, 02:30:02 am »
I have a machine with a metal control panel. The original Seimitsu's were the perfect height: as your hand cupped around the ball top, the outside of your palm rested right on the panel.
I was under the impression the stock U360 shafts were to match up similarly, but they are a good centimeter taller. Same, whether ball or tab top. Not bad, but not that 'oooooooo'. I'm thinking of modding the shaft a little shorter. Has anyone had a similar experience?...done what I'm thinking of doing?
-Banned-
TopJimmyCooks
Re: U360 shafts with metal CP (?)
« Reply #1 on: June 08, 2011, 09:07:46 am »
If you disassemble the sticks and take the shaft to a machine shop, they can cut, turn them down and rethread, since you're taking off a whole centimeter that will give them fresh, full diameter steel to work with. You'll lose the chrome, shouldn't be a big deal.
If you find a cool old cooter machinist it would probably be $50.  If its a new professional shop they won't want to talk to you.
If you are OK with the throw, you might consider spacing the joystick body down 1 cm from the underside of the panel to get your height without reducing throw.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: June 08, 2011, 11:23:18 pm »
If you disassemble the sticks and take the shaft to a machine shop, they can cut, turn them down and rethread...
Why would they need to be 'turned down'?
-Banned-
TopJimmyCooks
« Reply #3 on: June 09, 2011, 09:23:45 am »
IIRc the threaded portion is smaller diameter than the shaft.  They will need to put it in a lathe and remove metal down to the diameter the threading die requires.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: June 12, 2011, 06:02:20 am »
Oh. I thought you meant turn down the whole shaft. Anyways, it would be cheaper to have Franco B make them from scratch...although I could probably swing some kind of connection locally. I just haven't bothered yet.
-Banned-
