Author Topic: Some Sort of Power Distributor  (Read 1506 times)
Mrephunk
  • Last login:July 17, 2012, 12:56:47 am
« on: June 03, 2011, 04:04:04 am »
I was looking for something that I can hook up to a 5v and a 12v power supply that will then distribute the power to other ports I can connect wires for LEDs to. I have seen such devices for car audio setups, but the gauges they are in are way to big, and I'm not sure they will work. I was thinking also I could piggyback one entire side of a barrier strip to the power supply but was thinking that something has to have been created that does this. Can anyone help point me in the right direction?
Bender
Re: Some Sort of Power Distributor
« Reply #1 on: June 03, 2011, 09:11:28 am »
never mind I mis read your post :(
just a terminal strip should do it
bkenobi
Mrephunk
« Reply #3 on: June 03, 2011, 06:14:36 pm »
not sure what you are pointing me too kenobi
bkenobi
« Reply #4 on: June 03, 2011, 07:31:38 pm »
Those are a variety of terminal strips available through AllElectronics.com.  I've ordered other stuff from them in the past, so I can say they are reputable.  Radioshack has some that work too.  The link was just to follow up on what Bender suggested.
If you want a direct link to one specific product, try this one.  It should work out for your needs.
http://www.allelectronics.com/make-a-store/item/TB-7/7A-12-POSITION-TERMINAL-BLOCK//1.html
