Author Topic: 13 years in the making, I'm finally getting started!  (Read 2971 times)
seven5
  • Last login:November 03, 2011, 12:29:28 pm
« on: June 01, 2011, 05:20:38 pm »
Hey guys, after 13 years of wanting to build a mame cabinet, I'm finally executing. I've spent the last couple of weeks catching up on the latest and greatest of what can be done and finally picked up a cabinet.
The cabinet was a converted X-Men VS Street Fighter. I can't figure out what it originally was, but it has a Sega emblem on the back with just FCC info on it. No model or serial numbers are on this thing. Either way, its got 6 buttons per person, perfect to get me started. It's got a 25" Zenith tube with a WG K7193 chassis.
I just took delivery of my j-pac and can't wait to get started, but a couple things are stopping me. First, I assumed this thing was a JAMMA cabinet, I'm a bit confused. The way the blue CPS2 board is attached is unlike most images I've found online. None of the harnesses are jumping out at me as THE jamma harness. I'm just a little confused. Can anyone help me identify all these hookups and plugs? (I've posted numerous photos below showing the cabinet).
The other thing is, I know that I'm supposed to un-attach the AC from the game board before I hook up the j-pac, but it looks like the power supply in this thing is a little more modern. Everything looks plugged in via molex. Do i just unplug the molex for the right lead? Anyone have a good idea which one it is?
The back of this thing is funky, you can see the cut out for the window to see in the cabinet, but thats basically all there is for access. I still haven't figured out how the back comes off, its like its just straight up glued to the side pieces. It's very odd. Any ideas on this would help a ton too.
I'm planning hooking up an Asus Pundit P1-AH2 with an Athlon 4400+ with 2GB of ram to it. It has an on board Nvidia 6150 I plan on using with Soft-15khz.
If anyone has any other good pro tips for me before I start digging into hooking this thing up to the j-pac, I'd LOVE to hear them!
Thanks so much to everyone in the community, you've already helped me a ton and I look forward to helping/getting help in the future!
Cabinet
Click for large view - Uploaded with Skitch
Rear of cabinet
View from behind the control panel
Closer look
Cabinet Innards
CPS2 board
Happ Power Supply
Side of Power Supply (5v knob? what for?)
Various Molex connectors
Isolating transformer?
Monitor Chassis (WG 25k7193)
Tube and hookups
Board hookups
Detailed board hookups
Video: WG k7193 + soft-15khz + onboard nvidia 6150
Computer: Asus Pundit P1-AH2 - Athlon 4400+ - 2GB - Windows XP
Re: 13 years in the making, I'm finally getting started!
« Reply #1 on: June 01, 2011, 05:31:45 pm »
That big connector that is plugged into your CPS2 board IS the JAMMA connector.  CPS2 also uses a kick harness for all the kick buttons (buttons 4-6).
seven5
« Reply #2 on: June 01, 2011, 05:39:30 pm »
So this thing right here is the actual jamma harness? Ok, it looked like individual pins connected to me.
Are the rest of the plugs all over the place normal? I was expecting just a single harness coming from the control panel. I'm also aware of the kick harness and prepared to do the wiring for the extra buttons to the j-pac.
seven5
« Reply #3 on: June 01, 2011, 05:57:14 pm »
Ok, excellent. I got the board unplugged and have slid it out. I noticed a certain molex connector that went directly out near the control panel and I think this is the AC power for the jamma stuff. Can anyone confirm this? The only other thing the power supply appears to be going to is the monitor with a THICK black cable. I think its going to the transformer first.
Here are a couple of shots:
Sorry for the blurry photos (camera phone)
If this indeed is the power for the jamma stuff, I can start connecting the j-pac correct?
seven5
« Reply #4 on: June 01, 2011, 06:15:33 pm »
The Power supply appears to be a Happ 80-0015-00
seven5
« Reply #5 on: June 01, 2011, 10:06:08 pm »
well, a pretty successful evening! I got the j-pac installed, the wires from the kick harness wired, and the monitor running.
I installed soft-15khz and ran avres but i still have quite a bit of issues with resolutions from games. And Maximus Arcade and the Windows XP desktop is pretty damn flickery. They're both running in 640x480.
I thought maybe i need my modelines specifically set, but I haven't been able to find any for my k7193. Is this something that would resolve this? What exactly should my next step be to get rid of this flicker and get my game resolutions more legit?
« Reply #6 on: June 02, 2011, 08:56:29 am »
What are you going to do with your Xmen vs SF board?
I've never tried soft-15 so I can' help you there.  Have you looked at all the soft-15 info here?
seven5
« Reply #7 on: June 02, 2011, 09:56:15 am »
I plan to sell it. So it doesn't die from non use in a closet.
