Author Topic: WTS player 3/4 connectors and contacts for konami and others [US WI Milwaukee]  (Read 2214 times)
runawayabc123
  • Last login:September 06, 2019, 09:58:20 am
wiring: http://arcadecontrols.com/BBBB/konami.html
The correct connector and contacts for games like teenage mutant ninja turtles, the simpsons, xmen, captain american and others by konami, data east and other mfgs.  These are the slot like connectors/pins.  2.50mm pitch (which fits unlike the 2.54mm pitch).  Hard to find in USA and harder to find without min purchase requirements.
$10 shipped for 2 connectors and 30 contacts (you'll likely on need 8 or 9 per connector).  I have them listed on ebay too if you want to go that road for $1 more.
These will ship via USPS standard, non-machineable mail.
jmike
I think this is what I've been looking for, do you know if it works on a Run and Gun 2 PCB?
runawayabc123
I do not know for sure.
What I can do is get the micrometer out tomorrow and measure the pins on my TMNT board so you can see if it matches yours.  Since your game is a konami '93 and the simpsons is konami '91, I would think so.  These are jst-nh connectors if that helps you.
runawayabc123
Well, no customary measurements because it wouldn't fit between the pins and it only goes to 1inch, which 15pins is longer than that.
So, from the cheap chi-com one with meteric sizes:
from the outside of pins 1 to 15 is 35.92mm
from the inside of pins 1-15 is 34.01mm (basiclly full length, less the size of two pins)
from the outside of pins 1-2 is 3.48mm
from the inside of pins 1-2 is 1.48mm (the space between two pins)
the width of pin 1 was .98mm (pin 15 was a little smaller, but it had a nick on it)
Please let me know what measurements you have.  Thanks.
jmike
Thanks for checking.
                    The person that sold me the runs and gun 2 board has the wiring I need.
runawayabc123
Bump.
Confirmed as fitting on:
Crime Fighters (it had 2player roms, so only fit tested)
Sunset Riders
TMNT
Simpsons
Coming soon: captain america and the avengers!
« Last Edit: June 14, 2011, 10:39:54 pm by runawayabc123 »
runawayabc123
Captain America works too.  :)
runawayabc123
Bump!
