Author Topic: Hantarex MTC-900E screen moves vertically  (Read 1221 times)
blagger
  • Last login:June 02, 2012, 06:31:41 pm
« on: May 17, 2011, 04:19:37 pm »
Hello all,
the monitor works fine for a half an hour and then the screen moves in vertical direction.
This cannot be solved permanently by adjusting the v-freq potentiometer.
I suspect some caps should be changed.
I have the schemactis diagram.
Should I change all caps on the Deflection board, or can someone help me to narrow it down to some special caps.
Thank you
