Author Topic: Windows XP, Groovy mame ati drivers, removing video modes.  (Read 2911 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
I'm setting up a new system with a ATI HD4350 and XP, using the ati drivers off of the groovymame site.
The monitor I'm using with this setup is a D9200, so I'd like to delete all the 15k modes for 640x480 and above.
Exactly how to I do this using the arcade_osd tool?
Thanks,
later,
dabone
  • Last login:Today at 10:07:50 am
Re: Windows XP, Groovy mame ati drivers, removing video modes.
« Reply #1 on: May 13, 2011, 11:40:19 am »
Thanks,
later,
dabone
Hi dabone,
Arcade_OSD can't remove any modes, just modify the existing ones. Anyway you shouldn't remove the modes labelled as "custom" above 640x480, like 752x560, etc., as they are actually used by GroovyMame for some vertical games, so there is a good reason to have them.
dabone
  • Time to work...
« Reply #2 on: May 13, 2011, 12:25:15 pm »
Well the first problem I have is mamewah starting up in 640x480 INTERLACED.... owww..
First off, what should I be refering to these drivers as? Do they have a name they are referred to so I can search?
Second, is there a way to configure it to use TRI-Sync monitors instead of straight 15k? My Monitor supports for 15k to 31.5k (Actually a little higher, it does 800x600 but not very clear)
later,
dabone
« Reply #3 on: May 13, 2011, 01:12:36 pm »
Probably the resolution you were using before for mamewah is missing now, choose another one (you'll have many available), or if you really need that one you can add it too (more on this below*).
I labelled them as "CRT_EmuDriver" to avoid referring to them as hacked or patched or whatever :)
There is a brief explanation in the site where you downloaded them, I still need to write a proper documentation in English, this is the Spanish site: http://postback.geedorah.com/foros/viewtopic.php?id=1424
However, inside the VMMaker.ini file you have some explanations in English that will help.
Sure. Open and edit VMMaker.ini, change the MonitorType option to "D9200" (it's "CUSTOM" by default). Also edit the MameExe field to point your Mame executable path. Save, and run VMMaker.exe, that will genate the video modes needed by your monitor. If everything goes right, restart the system.
Then choose D9200 in mame.ini too and run GroovyMame.
*At this point, run Arcade_OSD to check the video modes that have been installed. See if any of them fits mamewah. Otherwise, create the mode you need by adding it in the ReslList.txt file and repeating the above process (run VMMaker, restart, etc.)
Good luck!
dabone
  • Time to work...
« Reply #4 on: May 13, 2011, 01:16:09 pm »
Thank you for the great reply!
Later,
dabone
