Author Topic: Rowe 100B bulbs  (Read 3027 times)
roguetel
  • Last login:June 08, 2013, 02:27:58 pm
  • arcade nostalgia, more addictive than heroin
Rowe 100B bulbs
« on: May 09, 2011, 08:18:31 pm »
Hi,
I have a ROWE CD100B jukebox just delivered! :afro:
I am very new to this jukebox so please bear with me! :o
The side bulbs are 11watt 130V colored and burnt out. Would a colored CFL work? I see they are rated power consumption 13watt and equal to 60 watt bulb, but am happy to replace with 130V 11 watt bulb if required. :dunno
Thanks and very excited, 250 watt coming out of this thing sounds so amazing.
Ken Layton
  • Guru
  • Technician
Re: Rowe 100B bulbs
« Reply #1 on: May 09, 2011, 10:33:49 pm »
The original bulbs are 11 watt "sign use" bulbs (S-11) commonly used in the sign industry and in carnival rides. Yes you can use the low wattage compact fluorescent lamps in there without a problem.
roguetel
Re: Rowe 100B bulbs
« Reply #2 on: May 12, 2011, 11:11:26 pm »
Ken, Thank you for your reply. The blue cfl's look great and add to the ambiance of the machine. The original color tubes are missing and my local arcade/pin/juke supplier says they usually break and doesn't have any.
I see you know your stuff and have seen your posts saying contact ROWE dealer for parts but any ideas? I'd like the motor and o-ring as well to complete the box.
Ken Layton
  • Guru
  • Technician
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe 100B bulbs
« Reply #4 on: May 19, 2011, 05:02:20 am »
Hi Roguetel,
I would not use CFL's they would be ok after being lit but would draw a high current on inital starting.
Happ may be your best bet but you should be able to order the 11 watt carnival lamps from any electrical supplier/wholeseller.
Regards
Alan Hood
ami-man
UK
