Author Topic: Can anyone tell me what kind of monitor this is , and adapter i might need ?  (Read 3149 times)
Jasonmm
  • Last login:July 30, 2021, 01:07:46 pm
So I bought this monitor on Ebay a year ago , I out bid 32 other people , so I thought it was safe ...
I finally open the box and I see this !!! What kind of adaptor is this ?
Thanks in advance for your help ....
this is the funky jack ...
thanks Jason
« Last Edit: May 02, 2011, 04:14:12 pm by Jasonmm »
Jasonmm
bump , added pics .... j
Kevin Mullins
    • Me on Myspace
That jack is designed to plug into things like slot machine and whatnot.
They just slide the monitor in and it mates up with the other half of the connector.
Ken Layton
  • Guru
  • Technician
It's for a video slot machine.
neoasura
Im also curious about this, is there a way to convert this
to use in an arcade cabinet? It does have a seperate VGA port. Itd be nice if
they had a power adapter for it.
BobA
  • What Me Worry?
This info might help you.  You would probably have to make your own adapter.
User Manuals and Schematics
neoasura
Ah, thanks for the info. Yeah, it seems to be able to take a VGA signal on the separate VGA adapter, so if I can figure out which is which pin for the power on the adapter...I could possibly rig something up. As it seems to just be getting power to the monitor is the issue.
shagster
  • Last login:May 08, 2011, 05:04:16 am
Over in this part of the world our AC wire colours are brown (Live) and blue (Neutral).
Looking at your last pic i'd bet thats what those two wires are in that pic,so they're prob your mains power. But maybe a pic of where they lead might help prove that!
Jasonmm
thanks ...
neoasura
@shagster , I think you're right. I see the blue and brown wires connected to the top most pins. They seem to be seperate leading away from the other wires. I've attached a pic. The next question I guess would be, if a simple splice to a standard 125v computer monitor  power cord directly to those wires would work? Or being that it's a different country code with I need some sort of inverter?
edit: I've been reading that most Euro/Korean countries use the 220v standard while America uses the 110v. So would I need a 220v outlet? The only thing I have for that is my washer lol.
« Last Edit: May 07, 2011, 01:29:53 pm by neoasura »
StephenH
  • Last login:January 09, 2023, 06:15:45 am
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBYQFjAA&url=http%3A%2F%2Fwww.jcmglobal.com%2FLibraries%2FProduct_Manuals%2FTovis_Color_Monitor_Mod_MTG-1902MM.sflb.ashx&rct=j&q=TOVIS%20MTG-1902&ei=YevFTf6QBZCftwfFmtGMBA&usg=AFQjCNGO7kg8sZSal_E1XQNMj3jgNyNo8Q&cad=rja
Above is a link to the monitor Manual.
Here is the Pinout of the AMP 25 Pin Connector:
 1 - Red
 2 - Video Gnd
 3 - Green
 4 - Video Ground
 5 - Blue
 6 - Video Ground
 7 - Shield
 8 - Horizontal Sync
 9 - Vertical Sync
10 - 12C Clk
11 - 12C SDA
12 - RXD
13 - TXD
14 - RESET
15 - NetGND
16 - Not Used
17 - Not Used
18 - Not Used
19 - Not Used
20 - Net13V
21 - 13VDC
22 - GND
23 - Frame GND
24 - AC Line
25 - AC Neutral
shagster
Nice StephenH ;)
Well looking at that manual it says its AC input is universal,so you shouldn't have any problems splicing those wires(blue 25 pin - brown 24 pin).
Connect the earth wire aswell(thats the green with yellow running threw it)to the monitor power cables earth wire that you're splicing.Looks like that pin number is 23.
« Last Edit: May 07, 2011, 10:49:25 pm by shagster »
neoasura
Wow, thanks for the good information there. And would you know it? After splicing the brown/blue wires with a standard monitor power cord, grounding the green wire, and taking cover...success! Power is going to the monitor :) All I need to do now is hook up the VGA to a computer to test the output, but thanks for all the help.
shagster
Glad you got it going without to much hassle ;)
  • Last login:Yesterday at 06:22:50 pm
taking cover
 :laugh2: i've been fixing things for years and i still do that!
