Author Topic: video problem with mamewah  (Read 1160 times)
Hoagie_one
  • Um....whats a cabinet
« on: August 27, 2003, 11:35:42 pm »
When I start up Mamewah for the first time on my mini cab it loads but i have a mostly grey screen.  I see the boxes where they are supposed to be and the bottom says no game available and i see teh main options box, but all the options are in an invisible text so that it will not show.  I can still selelct them, but i do so blindly.
Any idea whats up.
Comp specs
333 k6-2
voodoo3 vid card
9" monitor using a 600 x 480 display
256 MB ram
Isometric Bacon
  • Last login:February 28, 2014, 08:53:57 pm
  • Lets get dangerous!
Re:video problem with mamewah
« Reply #1 on: August 28, 2003, 04:33:58 am »
Have you tried unzipping the layouts.zip in the mamewah directory? I had the same problem when I first installed it.
Also, you didn't network across mamewah did you? You might wanna try a fresh install.
« Reply #2 on: August 28, 2003, 07:36:43 am »
Isometric Bacon is right I suspect - make sure you unzip 'LAYOUTS.ZIP' to the MAMEWAH installation folder, and also tick 'Use folder names' if using WinZip (or equiv.)...
Hoagie_one
« Reply #3 on: August 28, 2003, 08:07:36 am »
fixed my problem.  Thanks all.  Works great now.
Just have to monky with the layout and all is good again.
