Author Topic: How to separate glued wood?  (Read 3482 times)
vast
  • Last login:June 27, 2023, 07:18:57 pm
« on: April 23, 2011, 05:09:16 am »
Spent most of yesterday glueing the battens for my project.
Having a test fit this morning it seems that one of the last pieces I glued is off...
Any advice on how to separate the 2 pieces?
Cheers
Re: How to separate glued wood?
« Reply #1 on: April 23, 2011, 09:14:52 am »
Usually a hammer will work for me.
If you rabbited or otherwise joined them though, you may end up needing to use a Flush cut saw.
Something like this
vast
« Reply #2 on: April 23, 2011, 10:50:37 am »
Well, I tried a very sharp & fine crafting knife in the seam to try and scrape / cut out some glue then went in with the hammer.
Oops!
I'll try and rescue it with some wood filler  :banghead:
« Last Edit: April 23, 2011, 10:52:08 am by vast »
Xiaou2
  • Last login:Yesterday at 09:24:42 pm
  • NOM NOM NOM
« Reply #3 on: April 24, 2011, 02:48:22 am »
Although too late, I second the Flush Cut saw.   Grab one at Harbor Freight if you can.  They are really cool.
 Its amazing how sharp they are, and they cut really fast with minimal effort.
The blades so thin, theres very little resistance from the material.. and the teeth are razor sharp.. and surprisingly, out of all the cuts Ive made, they still are sharp as hell.
 Its nice to for small cut jobs, or specialty situations, like what you ran into. (which is their intended purpose)
vast
« Reply #4 on: April 24, 2011, 01:23:08 pm »
Thanks for the advice guys.  Operation wood filler was a success  :cheers:, it's really hard to see that a piece was missing after all the sanding.
I'll grab a flush cut saw for the future
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« Reply #5 on: April 25, 2011, 03:48:47 am »
If this is wood glue then the bond is stronger than the wood itself, so you have to treat it as though it's one piece and saw accordingly.
Darren Harris
Staten Island, New York.
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
