February 09, 2026, 11:33:26 pm
You don't have to worry about it toppling over. 3/4 inch mdf or ply is pretty heavy, and the LCD will probably weigh 20 lbs, max. Mine is 16 inches by 24 inches at the base and is plenty stable
Quote from: Donkbaca on April 22, 2011, 10:40:07 pmYou don't have to worry about it toppling over. 3/4 inch mdf or ply is pretty heavy, and the LCD will probably weigh 20 lbs, max. Mine is 16 inches by 24 inches at the base and is plenty stableNice! Thanks for your dimensions!
I've been looking at the same kind of project, and located this post in the huge Woody thread (insert Beavis laugh here) with a nice Sketchup model:http://forum.arcadecontrols.com/index.php?topic=55789.msg1108808#msg1108808I'll most likely be basing my cab off of this. I love the look of the awesome Terminus cab, but I suspect it's beyond my meager woodworking abilities...
Quote from: alfonzotan on April 23, 2011, 08:56:04 amI've been looking at the same kind of project, and located this post in the huge Woody thread (insert Beavis laugh here) with a nice Sketchup model:http://forum.arcadecontrols.com/index.php?topic=55789.msg1108808#msg1108808I'll most likely be basing my cab off of this. I love the look of the awesome Terminus cab, but I suspect it's beyond my meager woodworking abilities...FYI I built that sketchup model off of the Woody dimensions that Knievel posted that are linked earlier in this thread. So its an attempt at least at accuracy.
