Author Topic: Mala - option in display section  (Read 2289 times)
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« on: April 22, 2011, 04:24:15 pm »
Hi!
i don't understand the 3 function marked in the photo:
who knows what to do with it?
OpFlash
  • Last login:October 31, 2017, 06:37:34 pm
Re: Mala - option in display section
« Reply #1 on: April 24, 2011, 08:26:45 pm »
As far as I know I believe this is useful when you are running a layout for mala that is set for lo rez probably when using an arcade monitor.  A layout that is fixed is retro GUI wich can be found on the mala website.  if youre running mala under a monitor that doesnt support the resolution of the fixed layout  this option can be used to force the layout to the proper resolution.  I am not 100 percent sure of this as i am new to mala and myself trying to get everything figured out but i hope that this helps a little.
