Author Topic: Can I use a VESA mount with this? (PIC)  (Read 1891 times)
DataWest
  • Last login:July 10, 2015, 06:15:35 pm
BobA
  • What Me Worry?
Re: Can I use a VESA mount with this? (PIC)
« Reply #1 on: April 16, 2011, 06:49:11 pm »
Hard to say without measurements but owing to the wide variation that the mount will take you are probably OK.   Measure the distance between the mount holes on the back of your TV.    Not knowing the overall size of your TV they might be 100x200 or 200 x 400 vesa or larger but the mount will adapt.
« Last Edit: April 16, 2011, 06:50:51 pm by BobA »
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: April 16, 2011, 07:24:14 pm »
Should be fine. There's only about 8 Vesa sizes and most manufacturers stick to around 4 of those. It's easy to modify if you need to custom bracket it anyway.
DataWest
« Reply #3 on: April 16, 2011, 09:03:20 pm »
Thanks everbody :)
DataWest
« Reply #4 on: April 22, 2011, 12:58:47 pm »
Got the mount last night, worked perfect. Almost ready to show off some pics
