Author Topic: recommended <$25 4-way?  (Read 3433 times)
jmohr1
  • Last login:July 28, 2011, 04:00:54 am
« on: April 08, 2011, 02:15:39 pm »
Hey there, building my first machine soon and still need to pick up a 4-way. I'm using 2 happ competition 8-ways (I know they aren't viewed as the best, even by me, but they feel the way I remember) and of course would love a real pac-man stick, but can't justify the cost. Can anybody recommend a 4-way that even comes close in feel on the cheap? Preferably one I could get with or replace with a white ball top? Thanks for any recommendations 8^]
edit: Forgot to mention it will be mounted in a wood panel 3/4"
« Last Edit: April 08, 2011, 02:17:19 pm by jmohr1 »
VanillaGorilla
  • Coin detected in pocket
Re: recommended <$25 4-way?
« Reply #1 on: April 08, 2011, 02:23:50 pm »
ggg true-4
RandyT
  • Last login:March 09, 2026, 05:14:12 pm
    • GroovyGameGear.com
« Reply #2 on: April 08, 2011, 06:41:45 pm »
The True4™ is good, but if you want a more "Pac-Like" experience, I think the 4-way version of the Leaf-Pro™ could be closer fit.  Pretty much everything else will have a longer throw that some will object to.  If ball color is more important than feel, there are a couple of other options not yet on the store which will get you 4-way restriction, and that white ball you are looking for.
RandyT
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: April 08, 2011, 11:50:20 pm »
Sanwa jlw-tm-8 makes an awesome 4 way stick, comes in many different colors, and will run you right around $25 shipped from lizardlick.com, depending on where you need it shipped to.
pinballwizard79
« Reply #4 on: April 10, 2011, 06:18:22 pm »
Necro
  • Last login:December 31, 2025, 03:36:17 pm
« Reply #5 on: April 10, 2011, 06:50:53 pm »
Tornado Terry's is quite possibly the worst website I've ever seen...or close to it.  Are they still in business and selling things?
pinballwizard79
« Reply #6 on: April 11, 2011, 01:31:27 pm »
It is a really bad website indeed
He still sells, yes.
jmohr1
« Reply #7 on: April 12, 2011, 07:09:40 pm »
Quote from: RandyT
...I think the 4-way version of the Leaf-Pro could be closer fit...
Thanks, that looks to be what I'm in the market for. Just a couple ?'s
1. Would I be able to comfortably bottom mount this under 3/4"?
2. Can the ball top be changed (and if so what size/thread are we looking at)?
3. If no to either 1 or 2, any other recommendations?
Thanks again to everyone for the responses.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: April 12, 2011, 07:29:32 pm »
Bob's is worse and, just to be fair, both are good sellers.
Working: Not Enough
Projects: Too Many
Progress: None
RandyT
« Reply #9 on: April 12, 2011, 08:11:01 pm »
Quote from: RandyT
The only sticks which one can mount "comfortably" in a 3/4" panel are going to be those with long shafts.  Long shafts usually mean long throws, which many tend not to associate with a good 4-way.  You would need to pocket out the underside to give you the length you want, unless you don't mind a short stick. The Pac-Man stick was pretty short, so you might be ok with it as is.
Not on these.  The Leaf-Pros are currently red only.
Not if the Leaf Pro is the kind of stick you are looking for.  There are pretty limited choices in that type of stick, but I do have some of the Zippyy and sanwa-inspired sticks, including an below-panel-switchable design, which can be configured for 4-way operation and have white balls as options.  But they play quite a bit differently.  Shoot me an email if you want one before I manage to get them on the store.
RandyT
Ginsu Victim
  • Comanche, OK -- USA
« Reply #10 on: April 12, 2011, 11:26:04 pm »
Avoid the Tornado Terry's Ms Pac 4-way. Go with one of GroovyGameGear's offerings.
jmohr1
« Reply #11 on: April 14, 2011, 02:44:43 pm »
Freakin' 'bout time someone made a 4-way/joystick joke 8^]
And Randy, thanks for the help. I ended up going with the leaf-pro and will just figure out a way to make it work in my panel.
Also while poking around picked up the PS3 XIN-MO encoder. My plan was to use the brains of 2 SF IV fight-sticks for ps3 and Mame compatibility, but this should give similar results with less work and let me keep the fight-sticks intact for p3/4 games. Wish I would've poked around your site when I picked up my other sticks and buttons, could've just gotten everything there; oh well, lesson learned for next time.
