Author Topic: Best way to fasten 2x4's for a cab frame  (Read 6476 times)
DataWest
  • Last login:July 10, 2015, 06:15:35 pm
« on: April 07, 2011, 02:42:51 pm »
What is the best way to fasten 2x4's together for a cab frame?
  • Last login:Yesterday at 04:55:22 pm
Re: Best way to fasten 2x4's for a cab frame
« Reply #1 on: April 07, 2011, 02:54:01 pm »
layer of glue, and screws
DataWest
« Reply #2 on: April 07, 2011, 03:02:27 pm »
Im trying to figure out what is going on here....
I cant see what he is screwed into.
« Reply #3 on: April 07, 2011, 03:04:49 pm »
Without seeing it closer, it appears that they removed half of the material from each 2x4 and made joints that way.  Seems like overkill.
DataWest
« Reply #4 on: April 07, 2011, 03:08:52 pm »
How would you do it? Glue and screw a connecting piece to each joint? Im just interested in the easiest way.  ;D
Tumerboy
  • Last login:February 09, 2023, 01:06:11 pm
« Reply #5 on: April 07, 2011, 04:25:29 pm »
It's called a Lap Joint
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #6 on: April 07, 2011, 04:27:23 pm »
Glue/Screw.
You really don't need 2x4s I am using 3/4" ply with 1x2's and some L brackets and its plenty sturdy
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #7 on: April 09, 2011, 10:31:33 pm »
You take a dado blade on a table saw and basically cut half way.
It is overkill, but makes for a very sturdy and heavy cab.
  Scratch built upright MAME Cab
Woodshop Flunky
« Reply #8 on: April 09, 2011, 11:16:41 pm »
Half lap joints with 2x4s is beyond overkill for an arcade cab.
Instead, get some 1x2 material.  Better yet, if you have access to a table saw, rip your own 2inch strips of 3/4 inch plywood and butt joint them with pocket hole screws (and glue).  This will produce a VERY strong carcass to build you cabinet around.
Metal brackets will also work, but I find them harder to use.
« Reply #9 on: April 11, 2011, 09:45:01 pm »
2x4s are total overkill.  Plywood or MDF does the job just fine.
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
« Reply #10 on: April 11, 2011, 10:50:51 pm »
I just finished my basic cab shell using biscuits, glue and some screws. This is 5/8" particleboard mind you and it's rock solid. Granted the laminate adds a lot of rigidity, but I only have the sides, bottom and back pieces glued and it ain't going nowhere! I haven't even braced it in the front or top yet.
