Author Topic: GroovyMame for arcade monitors version 0.146u4_013f  (Read 307840 times)
jimmy2x2x
Re: GroovyMame for arcade monitors version 0143.013
« Reply #560 on: March 17, 2012, 03:59:04 pm »
Quick question about the filename, does the '013f' indicate the version of the groovymame patches?
  • Last login:March 15, 2026, 04:39:26 pm
« Reply #561 on: March 17, 2012, 04:29:59 pm »
That's it.
013f fixes some problems with the -changeres option, will add extended info later...
jimmy2x2x
« Reply #562 on: March 17, 2012, 04:50:47 pm »
Cool, would like to know whats new so I can test it out..
off to try a few of my problem games from 0.145 build see if there is any difference
Paradroid
    • SCART Hunter
« Reply #563 on: March 17, 2012, 10:12:50 pm »
Thanks for the v0.145u4 build and upload Calamity! Much appreciated. I'm halfway through installing the external controls on my Blaupunkt television. Once that's done this new build will be a nice way to celebrate! :) Cheers!
jimmy2x2x
« Reply #564 on: March 18, 2012, 04:23:16 pm »
Didn't want to make a new thread for this, but congrats and good luck to Calamity!
http://forum.arcadecontrols.com/index.php?topic=118940.0
« Reply #565 on: March 18, 2012, 05:25:53 pm »
Yes it's been a nice surprise  :)
Thanks!!!
Paradroid
    • SCART Hunter
Congratulations!
« Reply #566 on: March 19, 2012, 02:39:12 am »
Congrats on the nomination! After all the help you've given me over the last 6 months, well, I had to vote for you! ;D
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
« Reply #567 on: March 25, 2012, 10:59:33 am »
This is really useful....
I am having one issue.  I used the "hack" to get Groovymame and HyperSping to get along.  The first time I did something wrong because I got alot of black screens with sound until I changed to D3D.  That problem is now solved, EXCEPT that Tempest is still having that issue.
I a using an ATI HD4650 and the log is attached.  Can anyone help me troubleshoot this?
Thanks.
dapsaille
  • Last login:July 13, 2019, 01:31:26 am
« Reply #568 on: March 28, 2012, 10:41:44 am »
Hi all,
 i've got some troubles getting Mame + groovy patches and SH3 drivers for Gentoo 64bits.
 Does someone have a working src archive or a 64bit linux build with Groovy patches and sh3 (even an old version) ?
 Thanks in advance  ;)
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #569 on: March 28, 2012, 03:30:14 pm »
Here's my Simpsons log for Calamity to take a look at. Music way out of sync, running between 95% and 103% Cheers!
« Reply #570 on: March 28, 2012, 04:49:08 pm »
Thanks.
Hi milhouse,
Thanks for posting this and sorry for the late answer. This tempest game is interesting, it's reporting a resolution of 640x480 vertical but for some reason it's treated as horizontal by the GroovyMAME patch, so when MAME tries to render the screen rotated it doesn't fit and that's why you see a blank screen.
SwitchRes v0.013e: [tempest] (1) vertical (640x480@60.00)->(640x480@60.00)->(640x480@60.00)
I don't have a clue why this is happening. I don't have a valid tempest rom to try either. Anyway I'll need to have a look at this game.
« Reply #571 on: March 28, 2012, 04:52:16 pm »
Everything looks fine in your log. Please check if your computer is capable of running this games at a constant 100% with regular MAME, or with GroovyMAME and the -nomodeline option.
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #572 on: April 12, 2012, 09:41:59 am »
Little update for groovymame patch (to compile against 0.145u6):
--- 0145u4_groovymame_013f.diff 2012-04-12 15:36:38.049538976 +0200
+++ 0145u6_groovymame_013f.diff 2012-04-12 15:36:38.055538820 +0200
@@ -22,7 +22,7 @@
  // the running machine
  #include "machine.h"
- #include "mame.h"
+ #include "driver.h"
 diff -Nru src/emu/emu.mak src/emu/emu.mak
 --- src/emu/emu.mak 2012-03-17 15:46:18.000000000 +0100
 +++ src/emu/emu.mak 2012-03-17 16:45:04.000000000 +0100
@@ -42,7 +42,7 @@
  OSDSRC = $(SRC)/osd
  OSDOBJ = $(OBJ)/osd
-@@ -317,8 +319,13 @@
+@@ -318,8 +320,13 @@
  $(EMUIMAGEDEV)/serial.o \
  $(EMUIMAGEDEV)/snapquik.o \
@@ -60,7 +60,7 @@
 diff -Nru src/emu/emuopts.c src/emu/emuopts.c
 --- src/emu/emuopts.c 2012-03-17 15:46:18.000000000 +0100
 +++ src/emu/emuopts.c 2012-03-17 18:19:08.000000000 +0100
-@@ -106,6 +106,7 @@
+@@ -107,6 +107,7 @@
  { OPTION_FRAMESKIP ";fs(0-10)",                      "0",         OPTION_INTEGER,    "set frameskip to fixed value, 0-10 (autoframeskip must be disabled)" },
  { OPTION_SECONDS_TO_RUN ";str",                      "0",         OPTION_INTEGER,    "number of emulated seconds to run before automatically exiting" },
  { OPTION_THROTTLE,                                   "1",         OPTION_BOOLEAN,    "enable throttling to keep game running in sync with real time" },
@@ -68,7 +68,7 @@
  { OPTION_SLEEP,                                      "1",         OPTION_BOOLEAN,    "enable sleeping, which gives time back to other applications when idle" },
  { OPTION_SPEED "(0.01-100)",                         "1.0",       OPTION_FLOAT,      "controls the speed of gameplay, relative to realtime; smaller numbers are slower" },
  { OPTION_REFRESHSPEED ";rs",                         "0",         OPTION_BOOLEAN,    "automatically adjusts the speed of gameplay to keep the refresh rate lower than the screen" },
-@@ -122,12 +123,12 @@
+@@ -123,12 +124,12 @@
  // artwork options
  { NULL,                                              NULL,        OPTION_HEADER,     "CORE ARTWORK OPTIONS" },
@@ -87,7 +87,7 @@
  // screen options
  { NULL,                                              NULL,        OPTION_HEADER,     "CORE SCREEN OPTIONS" },
-@@ -197,11 +198,37 @@
+@@ -198,11 +199,37 @@
  { OPTION_RAMSIZE ";ram",                             NULL,        OPTION_STRING,     "size of RAM (if supported by driver)" },
  { OPTION_CONFIRM_QUIT,                               "0",         OPTION_BOOLEAN,    "display confirm quit screen on exit" },
  // MKChamp Hiscore Diff options
@@ -235,15 +235,15 @@
 diff -Nru src/emu/machine.c src/emu/machine.c
 --- src/emu/machine.c 2012-03-17 15:46:18.000000000 +0100
 +++ src/emu/machine.c 2012-03-17 16:45:04.000000000 +0100
-@@ -189,6 +189,7 @@
+@@ -188,6 +188,7 @@
  memset(gfx, 0, sizeof(gfx));
- memset(&generic, 0, sizeof(generic));
  memset(&m_base_time, 0, sizeof(m_base_time));
 + memset(&switchRes, 0, sizeof(switchRes));
  // set the machine on all devices
  device_iterator iter(root_device());
-@@ -264,6 +265,9 @@
+@@ -263,6 +264,9 @@
  // allocate a soft_reset timer
  m_soft_reset_timer = m_scheduler.timer_alloc(timer_expired_delegate(FUNC(running_machine::soft_reset), this));
@@ -256,20 +256,20 @@
 diff -Nru src/emu/machine.h src/emu/machine.h
 --- src/emu/machine.h 2012-03-17 15:46:18.000000000 +0100
 +++ src/emu/machine.h 2012-03-17 16:45:04.000000000 +0100
-@@ -418,6 +418,9 @@
+@@ -407,6 +407,9 @@
  // debugger-related information
  UINT32 debug_flags; // the current debug flags
 + // SwitchRes patch
-+ SwitchRes switchRes; // SwitchRes data
++ SwitchRes switchRes; // SwitchRes data
- // generic pointers
- generic_pointers generic; // generic pointers
+ // internal core information
+ palette_private * palette_data; // internal data from palette.c
+ romload_private * romload_data; // internal data from romload.c
 diff -Nru src/emu/render.c src/emu/render.c
 --- src/emu/render.c 2012-01-24 15:18:56.000000000 +0100
 +++ src/emu/render.c 2012-03-17 16:45:04.000000000 +0100
-@@ -1203,10 +1203,54 @@
+@@ -1204,10 +1204,54 @@
  void render_target::compute_visible_area(INT32 target_width, INT32 target_height, float target_pixel_aspect, int target_orientation, INT32 &visible_width, INT32 &visible_height)
  float width, height;
@@ -326,7 +326,7 @@
  // start with the aspect ratio of the square pixel layout
  width = m_curview->effective_aspect(m_layerconfig);
-@@ -1221,9 +1265,9 @@
+@@ -1222,9 +1266,9 @@
  // based on the height/width ratio of the source and target, compute the scale factor
  if (width / height > (float)target_width / (float)target_height)
@@ -338,7 +338,7 @@
  // stretch-to-fit case
-@@ -1231,12 +1275,12 @@
+@@ -1232,12 +1276,12 @@
  width = (float)target_width;
  height = (float)target_height;
@@ -354,7 +354,7 @@
-@@ -1343,7 +1387,7 @@
+@@ -1344,7 +1388,7 @@
  root_xform.yscale = (float)visheight;
  root_xform.color.r = root_xform.color.g = root_xform.color.b = root_xform.color.a = 1.0f;
  root_xform.orientation = m_orientation;
@@ -363,7 +363,7 @@
  // iterate over layers back-to-front, but only if we're running
  if (m_manager.machine().phase() >= MACHINE_PHASE_RESET)
-@@ -1372,7 +1416,7 @@
+@@ -1373,7 +1417,7 @@
  item_xform.color.b = curitem->color().b * root_xform.color.b;
  item_xform.color.a = curitem->color().a * root_xform.color.a;
  item_xform.orientation = orientation_add(curitem->orientation(), root_xform.orientation);
@@ -1932,7 +1932,7 @@
 diff -Nru src/mame/drivers/galaxian.c src/mame/drivers/galaxian.c
 --- src/mame/drivers/galaxian.c 2012-03-17 15:45:37.000000000 +0100
 +++ src/mame/drivers/galaxian.c 2012-03-17 16:45:05.000000000 +0100
-@@ -2016,7 +2016,7 @@
+@@ -2113,7 +2113,7 @@
  static MACHINE_CONFIG_START( galaxian_base, galaxian_state )
  /* basic machine hardware */
@@ -1941,7 +1941,7 @@
  MCFG_CPU_PROGRAM_MAP(galaxian_map)
  MCFG_CPU_VBLANK_INT("screen", interrupt_gen)
-@@ -2119,7 +2119,7 @@
+@@ -2216,7 +2126,7 @@
  MCFG_CPU_VBLANK_INT("screen", fakechange_interrupt_gen)
@@ -1950,7 +1950,7 @@
  MCFG_CPU_PROGRAM_MAP(tenspot_select_map)
  //MCFG_CPU_VBLANK_INT("screen", nmi_line_pulse)
-@@ -2235,7 +2235,7 @@
+@@ -2328,7 +2328,7 @@
  MCFG_CPU_IO_MAP(mshuttle_portmap)
  /* sound hardware */
Earth could be the hell of another world
« Reply #573 on: April 12, 2012, 01:57:53 pm »
That's great Ansa89, thanks a lot!
evh347
  • Last login:July 22, 2022, 04:58:20 pm
« Reply #574 on: April 15, 2012, 05:00:28 pm »
I'm having the same problem...Mame .145 and Tempest audits good...boots to a black screen.
jrose78
  • Last login:June 22, 2015, 10:52:58 am
« Reply #575 on: April 18, 2012, 08:23:01 am »
I have galaga that boots to a blank screen but audio continues. If I disable hlsl it works.
Megaweapon
  • Last login:July 30, 2022, 09:58:51 pm
  • 40 Megatons of Fun
Re: GroovyMame for arcade monitors version 0145.013e
« Reply #576 on: April 22, 2012, 07:05:21 pm »
Compiling notes
Apply patches in this order:
1) hi_145.txt (http://mamestuff.lowtrucks.net/MKChamp/)
2) 0145_groovymame_013e.diff (http://mario.groovy.org/GroovyMame/WindowsATIDrivers/)
This is consistently failing to compile for me at the same place:
Compiling src/mame/drivers/taitopjc.c...
src/mame/video/taitojc.c: In function 'UINT32 screen_update_taitojc(device_t*, s
creen_device&, bitmap_ind16&, const rectangle&)':
src/mame/video/taitojc.c:318: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make: *** [obj/windows64/mame/video/taitojc.o] Error 1
make: *** Waiting for unfinished jobs....
F:\mamesrc>
I am using MAME 145 (no 'u') source with the above two diffs applied in the correct order under WinXP x64 with 64-bit MinGW (no compiler front end, just Mr. Do's instructions).
Anyone else seeing this?  Any suggestions?
Uhh, boy I don't know.  We always used to refer to him as just 'That Paper Chase Guy'...
Ansa89
« Reply #577 on: April 23, 2012, 04:21:31 am »
Could be related to this?
Moreover, remember there is a precompiled executable for windows.
Megaweapon
« Reply #578 on: April 23, 2012, 07:06:34 pm »
I applied the fix in the post you linked to the groovymame diff and did a clean compile but it still failed with the same error.
I'm still getting nag screens with the precompiled groovymame executable.  Am I doing something wrong?
« Reply #579 on: April 24, 2012, 06:17:06 pm »
Hi Megaweapon,
The error you are reporting is a segmentation fault of the compiler itself, not an error in the source code. Try using MAME Compiler, it's what I use to make the Windows builds.
The nag screens are enabled by default so we don't violate MAME's license. You need to manually disable it through the option you'll find inside mame.ini (generated by groovymame).
krick
  • Gotta have blue hair.
« Reply #580 on: May 03, 2012, 12:43:41 am »
Hi Calamity,
I was trying to compile the x64 version of GroovyMAME tonight, and I think I found a small bug that would only affect the Windows x64 version, and only at compile time.  In osd\windows\window.c, you're patching in the following snippet:
@@ -1431,6 +1543,8 @@
  // syscommands: catch win_start_maximized
  case WM_SYSCOMMAND:
+ mame_printf_verbose("window_proc: WM_SYSCOMMAND %d\n", wparam);
  // prevent screensaver or monitor power events
  if (wparam == SC_MONITORPOWER || wparam == SC_SCREENSAVE)
  return 1;
The problem is, in the x64 compiler, the wparam variable (a WPARAM type) is a 64-bit integer, and doesn't like being printf'd as a %d.  Casting it to a 32-bit integer lets it compile fine.  More info here.
This should fix it (it compiles at least, will let you know if I run into any bugs when I get a chance to use it):
  case WM_SYSCOMMAND:
+ mame_printf_verbose("window_proc: WM_SYSCOMMAND %d\n", (UINT32)wparam);
  return 1;
Cheers - I really appreciate all you're doing for the community!
I don't have a system that I can compile this on at the moment to test, but I think that a better solution than casting the WPARAM is to use %p as the format instead of %d.  WPARAM is a pointer.   %p should print the pointer in hexadecimal regardless of size without truncating.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
« Reply #581 on: May 07, 2012, 05:51:47 am »
Hi guys,
Chris Kennedy (bitbytebit), the GroovyMAME/GroovyArcade creator as you know, is not going to be actively involved with the project for a while, hopefully we have him back here at some point. He proposed Ves and I to open a new site to host the project files. By now, we've started a project in Google Code:
http://code.google.com/p/groovyarcade/
This site will contain GroovyMAME binaries, diff files and other related stuff. We still need to set up the git so you can browse the source code etc., otherwise I don't believe we'll be allowed to nest in there for too long. We'll probably need to open a separate ftp at some point to host the GroovyArcade iso files.
My intention is to keep GroovyMAME updated to mainline MAME, it's a big challenge considering I'm not a C++ programmer. VeS for his part will keep GroovyArcade updated to the Linux kernel. I like to think of this project as a collective task, so don't hesitate to get involved.
An interesting battlefront could be updating the Switchres code. Since Chris integrated Switchres into MAME, so GroovyMAME was born, the Switchres project has been somewhat frozen. All the attention and development went into GroovyMAME, so the Switchres standalone program now lacks many of the features that were added to GroovyMAME recently.
On the other hand, the GroovyMAME patch needs a partial rewrite. Though it has worked quite well for most situations, your intensive tests have revealed many issues here and there that need to get targeted at some point. Most of these issues point to the project's real Achilles heel, the routine that's resposible for picking the best mode from the ones available in the system. But also the way the monitor_specs are defined needs to be slightly changed so the user can finally get full control on the modeline generator's output.
As for the CRT_Emudriver, well I don't think those can fit in Google Code, mainly because of their hacky nature, but also because the Google Code is only supposed to host binaries from the project's open source code. So by now they'll be available from download sites like this:
http://hotfile.com/dl/153631406/c6c491e/crt_emudriver_6.5_1.2_x64_multisync.rar.html
http://hotfile.com/dl/153629728/4e81a27/crt_emudriver_6.5_1.2_xp32_multisync.rar.html
http://hotfile.com/dl/153633303/6af9a89/crt_emudriver_9.3_1.2a_x64_multisync.rar.html
http://hotfile.com/dl/153632251/22a3edd/crt_emudriver_9.3_1.2a_xp32_multisync.rar.html
Someone suggested the possibility to provide diffs or a patcher for the Catalyst stuff instead of the full binary download in order to keep safe. Well, that would be possible but unfortunately there's more than patching the files. In order to get Windows to accept the drivers you need to obtain new hashes with a specific tool that's only available from Microsoft SDK. After my experience solving people's plain drivers installation related issues, trust me when I say that this route is not viable.
lettuce
  • Make It So!
« Reply #582 on: May 07, 2012, 06:24:45 am »
Shame about Chris leaving the project, i sure hope he is in good health and so will be onboard aagin soon?
But im glad that this project is being kept alive as it is a godsend for us anal MAME'ers, keep up the sterling work Calamity and Ves!!. Hopefully the little bugs GrooyMAME has get squashed at soon
Paradroid
    • SCART Hunter
« Reply #583 on: May 07, 2012, 07:43:02 pm »
A lofty ambition! Sounds like some exciting things are on the way, time permitting...
Thanks again for all the work you guys have put in! :) You've re-defined just how perfect "arcade perfect" emulation can be. ;)
Abubu
  • Last login:June 04, 2016, 02:32:01 pm
« Reply #584 on: May 07, 2012, 09:25:12 pm »
I hope you'll manage to keep up the good work guys!
I'm not a C++ programmer, but I have a lot of space on my FTP server. If you need a place to store your files or just a mirror, send me a message :)
Good luck and thanks for your amazing version of mame!
krick
« Reply #585 on: May 08, 2012, 12:47:15 am »
I'm excited about the Google Code site.   I think the project can really benefit from some proper bug tracking and wiki documentation.
I think one thing that's really needed is a list of specific problem games and edge cases so that each build can be properly regression tested.
Hantarex Polo 15KHz
Ansa89
« Reply #586 on: May 08, 2012, 08:18:14 am »
A little typo in the main description: "It uses AdvanceMAME or" should be "It uses AdvanceMenu or".
lettuce
  • Make It So!
« Reply #587 on: May 08, 2012, 02:01:09 pm »
Is there a new version of VMmaker out?, as i noticed in Calamity's Monitor Present thread that one of the default modeline spec is 'CGA' but in the version of VMMaker i have there is no 'CGA'?
« Reply #588 on: May 08, 2012, 02:42:26 pm »
I've attached the latest beta (I already did it in some other thread).
This one has native support for magic resolutions (you only need to use the right option in the ini), uses the same format for monitor_specs as GroovyMAME, and should work more eficiently when creating mode list for multisync setups.
The CGA setup is not in VMMaker, I just added it to that post because it's the values GM picks by default (and labels as 'cga' in the logs).
« Reply #589 on: May 08, 2012, 02:45:23 pm »
Well spotted, thanks.
« Reply #590 on: May 08, 2012, 02:48:52 pm »
The Google Code thing is quite a new one to me, hopefully we figure it out and can benefit from its features.
I get your point on the test list of games, it's something that I really want to get done soon.
« Reply #591 on: May 08, 2012, 02:57:55 pm »
Thanks a lot for your offering, this could be a nice solution actually. Well I don't know how much bandwidth this can actually consume, probably the isos are the most problematic thing to host, I don't think these are downloaded by thousands anyway...
Abubu
« Reply #592 on: May 08, 2012, 03:36:48 pm »
I have sent you a private message.
Best regards.
lettuce
  • Make It So!
« Reply #593 on: May 08, 2012, 03:38:45 pm »
Ok cool, just that ive got hold a, HANTAREX CT 28 EQ MONITOR the type thats in a TV case. As its a CGA monitor just wanted to know if i use that as monitor type or edit the monitor_spec line?
« Reply #594 on: May 13, 2012, 11:00:54 am »
Thanks A LOT to Abubu for providing us with a ftp for hosting the GroovyArcade iso files.
Now the download links can be found in the main page at http://code.google.com/p/groovyarcade/
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #595 on: May 15, 2012, 07:55:23 am »
Update groovymame 145u8
Calamity please review the updated
Groovymame145u8 windows
http://code.google.com/p/groovyarcade/downloads/list
I will try to make the linux version this afternoon.
Thank you very much Abubu!!!!
jimmy2x2x
« Reply #596 on: May 15, 2012, 02:58:32 pm »
Very nice, any chance of a 64 bit build please?
Thanks for all the effort guys, really appreciate it
« Reply #597 on: May 15, 2012, 06:16:16 pm »
GroovyMAME 0.145u8 64 bit build uploaded...
ufoufo512
  • Last login:September 22, 2016, 02:09:41 pm
« Reply #598 on: May 16, 2012, 02:51:30 pm »
Thank you for continued support for this amazing project. I used to have Groovy Arcade Linux installed on my cab. It was a version before Groovy used Linux kernel version >= 3. Yesterday, I tried to update my installation. Unfortunately I didn't remember all the tweaks I made last time to get it running. My problems were following:
1) I couldn't get the wlan adapter to work. With the old setup it didn't work either before I manually edited the wpa_supplicant.conf file. I only had to edit the proto (protocol) to get it work last time, but now it doesn't help. If I run wpa_supplicant -B -Dwext -c/etc/wpa_supplicant.conf -iwlan0 and after that dhcpcd wlan0 the machine is now connected. It just that those things are not happening when the system boot automatically, or am I missing something essential (probably)?
2) Even bigger problem is that I cannot start Advmenu Frontend or Groovymame. Some text is displayed and after that Groovy Arcade Linux setup screen is displayed. If I select "Exit to shell" and try to start Advmenu by typing advmenu, I get an error just saying "Illegal command(or instruction [I don't remember now which])". If I try to start Groovymame by typing groovymame I get error message saying "Can't open display". I kind of remember that I changed the mame.ini video to soft instead of opengl previously, but that can be a false memory. I tried it now with the new version as well, but it didn't make a difference.
 My setup is fairly antique. Pentium IV and Radeon 7000 (AGP), but it used to work previously. Of course if it is not anymore supported, I have to upgrade it or get the old version back. The new version I tried was this: http://www.aburamushi.net/calamity/GroovyArcade-Arch2012.03.25-i686.iso
« Last Edit: May 16, 2012, 03:01:36 pm by ufoufo512 »
Ansa89
« Reply #599 on: May 17, 2012, 09:30:11 am »
In attach the updated patch for wiimote support.
