Author Topic: Cheap router question  (Read 2797 times)
DataWest
  • Last login:July 10, 2015, 06:15:35 pm
« on: April 06, 2011, 09:18:30 am »
I'm no carpenter so I don't have or know anyone that has a router.
I literally need to route out 4 joystick holes...that's IT.
Would it be best to rent one from the big box stores (has anyone done this?)? Or buy the cheapest I can find to hold up for the one job? What are some ballpark prices?
TopJimmyCooks
Re: Cheap router question
« Reply #1 on: April 06, 2011, 11:22:42 am »
The cheapest way out is harbor freight tools.  They have a $25 trim router and probably a straight cutting bit with bearing for $10 or so.  What are you routing?  if it's mdf or particle board, no problem.  if plywood, its a little sketchy.
If you go this route check back for advice, there's a lot of potential issues.  Trim routers have square bases and no template guides so you have to have a guide bearing bit.  No plunge capability so you have to be able to drill a starter hole.  Remember you're breaking a rule about cheap import tools:  you are buying a potentially dangerous, precise and complex tool so prepare for compromise.  Should be able to accomplish 4 holes anyway.
Routers also multiply like rabbits.  I currently have 6 of varying sizes.
DataWest
« Reply #2 on: April 06, 2011, 11:29:56 am »
Im going to route out 1/2'' MDF for 4 aluminum plates for my Sanwa sticks to mount into. Like this http://forum.arcadecontrols.com/index.php?topic=109040.msg1162414#msg1162414  he did the same thing with his joysticks.
TopJimmyCooks
« Reply #3 on: April 06, 2011, 12:31:17 pm »
Do you have the capability to cut out templates?  a drill with a 1/2" bit and a jigsaw or keyhole saw?  with those and the laminate trimmer (small router) you are in business.  Usually top mount routing is done with 2 templates - one for the hole the joystick chassis goes all the way through and then a larger one for the mounting plate that is recessed.
If you are covering the CP with artwork, it is possible to just make layout marks on the MDF and freehand it.  Possible, but difficult and more irregular looking cuts, with more potential to screw up your workpiece and have to start over.  I have seen several do it that way.
DataWest
« Reply #4 on: April 07, 2011, 02:43:57 pm »
Yeah Im going to borrow a jig and a router now. Thanks!
JackLeather
  • Last login:March 24, 2013, 06:31:46 am
« Reply #5 on: April 21, 2011, 12:31:08 pm »
Cool. Now the problem is that i am in the UK  :(
Do any Brits know of a similar 'trim router' over here? by similar i mean cheap...
