Author Topic: joystick issues with hyperspin  (Read 5553 times)
Rice Cube
  • Last login:January 04, 2016, 02:51:06 pm
« on: April 04, 2011, 02:30:15 pm »
hey everyone, i accidentally set my joysticks incorrectly. the left side is set as player 2 and the right side is set to player 1. i go into hyperhq to set the IDs correctly but each time a window comes up saying that it cant be set because it is being occupied. anyone know how to fix this? thanks
« Last Edit: April 09, 2011, 06:00:35 am by flipwitnrg »
Rice Cube
Re: switch/change player IDs for joysticks in hyperspin
« Reply #1 on: April 07, 2011, 11:36:42 pm »
fixed it
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
« Reply #2 on: April 08, 2011, 12:40:26 am »
I would be nice to say how you fixed it, in case someone else has the same problem  ;)
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: April 08, 2011, 07:34:01 am »
Just load the settings.ini into a text editor and change the ID number.
loadman
    • MaLa
« Reply #4 on: April 08, 2011, 09:45:26 pm »
If you have issues at a windows assignment level I find this a great free tool:
http://www.wingmanteam.com/files/Tools/JoyIDs/JoyIDsInstall.exe
Rice Cube
Re: joystick issues with hyperspin
« Reply #5 on: April 09, 2011, 06:08:15 am »
Ok this is what I figured out so far. Also BTW, i am using akishop ps360 PCBs to hook up joysticks and pushbuttons.
For some reason, my left set of buttons and joystick reads as player 2 and the right side as player 1. i can uninstall them and then do one by one, reinstall them and set the joysticks correctly so they are working. after i reinstall them and configure them, i try them out in hyperspin and everything is working. if i turn off the computer and then turn it back on, it goes back to my left side reading as player 2 and my right side as player 1.
its weird because i can uninstall them both, install the left side as player again 1 but not touch anything with player 2 and player 1 will be working fine, i can then turn off my computer and boot it back up with player 1 still working correctly. but for some reason when i try and incorporate 2 players it reads wrong. any help would be much appreciated, ive been working on this issue for like a week and some.
after typing this, im thinking maybe my boards cant be used at the same time since they are separate, unlike an ipaq where its all in one piece.
