Author Topic: invisible mouse cursor???? (already searched, but still have questions)  (Read 1600 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
i searched for "invisible mouse" in the search engine and found this thread http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=8965  but i still dont know which way to go.  my mouse cursor comes up like every game....almost anyway...its so friggin annoying!  how do i get my mouse cursors to go away???  i mean, i may want them for maintenence in windows, so that means i dont want to make them invisible in editing files or whatever....ah....im getting confusing...what do i do?
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re:invisible mouse cursor???? (already searched, but still have questions)
« Reply #1 on: August 26, 2003, 02:28:38 pm »
Two options that I can think of...
1. I believe there are programs that hide mouse cursors.  I dont know what they are called.  Anyways, run this before you run mame, and then shut down this program after you are done.
2. Use a mouse cursor or icon editor to create your own "almost invisible" cursor.  Create a cursor that consists of a single pixel so that its hardly noticible but you could see it if you needed to actuallly use it in Windows.
Lilwolf
« Reply #2 on: August 26, 2003, 02:32:35 pm »
I just added it to my frontend.  But it's still annoying.
1) it doesn't clea until it moves (I think I can fix this)
2) it shows up for a second when going full screen.
BUT...
if you remove it for good in windows... good luck trying to get windows to work when you need it.
You COULD try creating a black cursor.  So it would be visible in windows blue background... And then it would be clear in mame when mame first starts up.
hulkster
« Reply #3 on: August 26, 2003, 03:39:53 pm »
okay so i could download the program....anybody know where that is?  or what are the good ones?
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #4 on: August 26, 2003, 03:57:13 pm »
There is an option in windows that might do the trick.  Check "hide pointer while typing" under control panel > mouse > pointer options.
« Last Edit: August 26, 2003, 03:57:49 pm by TalkingOctopus »
hulkster
« Reply #5 on: August 26, 2003, 04:18:37 pm »
what OS are you using?  i have 98 and 2000 and its not on either.
TalkingOctopus
    • My Arcade
« Reply #6 on: August 26, 2003, 04:33:21 pm »
XP but I think it should be in any of those, maybe under a different menu.
« Last Edit: August 26, 2003, 04:33:53 pm by TalkingOctopus »
