Author Topic: Scrambled/rolling display - J-PAC, ArcadeVGA, Thomson tube  (Read 3185 times)
stamps
  • Last login:April 02, 2011, 09:32:39 pm
« on: March 31, 2011, 03:53:33 am »
Hi guys!
I just picked up a sit-down 2player cab for cheap, and replaced the dodgy Chinese PC inside.
The new PC has an ArcadeVGA 3000 and is interfaced to the cabinet via JAMMA with a J-PAC.
My problem: I can't output any video that the monitor will display.  Everything is scrambled/rolls like I've got the wrong resolution or refresh rate. :(
  • ArcadeVGA 3000 and J-PAC
  • ArcadeVGA drivers installed, 640x480 chosen in quickres utility
  • Rolling/scrambled screen all the way from POST into Windows (Windows 7 64bit)
  • Tested output to an LCD monitor via the ArcadeVGA DVI connection: OK.
  • Tried all combinations of jumpers on J-PAC: 15Khz+31KHz and 25KHz-only (also tried removing all jumpers for the composite sync.)
  • The self-test LED on the J-PAC is lit solid.
Here's the only info I can see on the back of the monitor:
Code: [Select]
  Thomson A68EMN021X0A1
  D-RNJD0399 [00]
  93701CSMCZ
  59241092386
  09/13/09
(The monitor works with the original PC in it, so the display itself doesn't seem to be faulty.)
Is anyone able to illuminate me?  Thanks heaps!
MonkeyJug
  • Last login:September 11, 2025, 04:54:07 pm
Re: Scrambled/rolling display - J-PAC, ArcadeVGA, Thomson tube
« Reply #1 on: March 31, 2011, 07:35:06 pm »
hi mate,
i'm no expert, but have you tried running the vga straight to the video card (bypassing the j-pac altogether)?
stamps
« Reply #2 on: March 31, 2011, 09:44:11 pm »
Hey MonkeyJug,
Good idea.  I haven't tried that yet.  But my understanding of the J-PAC is that it doesn't modify the video signal at all, it just passes-through - but only if the signal is 15 or 25KHz (depending on jumper setting.)  I'll give the direct connection a go when I get home!
gavincoolguy
  • Last login:November 03, 2011, 07:51:34 pm
« Reply #3 on: April 01, 2011, 02:53:41 am »
I'm no expert but did you at least adjust the horizontal and vertical sync after changing everything out ?
stamps
« Reply #4 on: April 01, 2011, 09:17:05 pm »
You may not be an expert, but I'm definitely an idiot.
I had no idea there was a dozen potentiometers on the monitor board to adjust the picture.  The H and V-sync was off so badly that I didn't even think about it.
Fixed! Thanks everyone for your patience  ;)
gavincoolguy
« Reply #5 on: April 02, 2011, 05:09:14 pm »
Woo glad I was able to help, only been actively participating in this hobby for 2 months or so.
