Author Topic: Getting Soft15Khz to work with Radeon HD 4350  (Read 4052 times)
SpongeFreak52
  • Last login:February 16, 2024, 03:40:02 pm
« on: March 25, 2011, 03:18:32 pm »
Hey all, I've got a desktop setup with an ATI Radeon HD 4350 installed (as I've heard it works well with Soft15Khz). However, I cannot seem to get Windows XP to boot up with the 15Khz successfully outputting. If I try to boot up normally, I get a double image every time.
The ONLY way I can get a good picture is if I hook the 4350 up to an external monitor, re-apply the video settings (literally clicking Apply in Display Settings again), then unplugging the monitor's VGA and plugging in the arcade monitor. After I restart the computer, I either go back to a double image or nothing at all.
I've heard that Windows 7 actually works with Soft15Khz on a 4350, but I'm curious to see if anyone has any suggestions for this.
Thanks a bunch!
  • Last login:Today at 04:27:17 pm
Re: Getting Soft15Khz to work with Radeon HD 4350
« Reply #1 on: March 25, 2011, 03:22:03 pm »
You actually need to use the dvi output of your 4350 instead of the vga, use a dvi-vga adapter for that.
SpongeFreak52
« Reply #2 on: March 25, 2011, 03:40:22 pm »
Oh my goodness, THANK YOU! I can't believe how simple a solution that was, me and my friend were literally experimenting with different software all night, I never thought that the DVI output was an option in this case.
Much appreciated, can't say how happy yet stupid I feel. :)
SailorSat
  • Last login:November 08, 2025, 04:24:41 pm
    • For Amusement Only e.V.
« Reply #3 on: March 26, 2011, 03:09:14 am »
Actually I'm impressed you got image in windows on the second head :)
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #4 on: March 26, 2011, 06:15:32 pm »
im using a sapphire radeon 4350 pci xpress low profile with dvi onboard and sub d analog breakout cable in my arcade box . the analog port works fine with soft 15 and xp . no probs at all . card was less than 30 euro on amazon .
