Author Topic: T-Molding questions  (Read 2596 times)
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
T-Molding questions
« on: March 24, 2011, 06:02:02 pm »
Do people typically run continuous t-molding on the sides of the cabinet completely under the CP?
Also what about the ends of the CP? I see some people make their CP box similar to the cab box, that is to say, the side pieces overlap and have T-Molding on the edges. This is nice because it eliminates a harsh edge/corner that you might bust your knee on, but I am unsure if this typcal.
Your thoughts?
BobA
  • What Me Worry?
Re: T-Molding questions
« Reply #1 on: March 24, 2011, 10:11:00 pm »
The area where the cp is placed does not need t molding. T molding where you are fastening the CP will probably just get in the way.  The outside edges of the cp however are usually banded with t molding.
DNA Dan
« Reply #2 on: March 24, 2011, 10:14:58 pm »
I think I might have to use t molding on this area anyway because my cab won't fit through a doorway with the CP installed. I need to be able to remove it.
grasspuddle
  • Last login:August 21, 2011, 12:43:26 pm
« Reply #3 on: March 29, 2011, 08:32:53 am »
If you just need to remove the CP when you move, there isn't a need for T-molding. I am just going to cover up exposed edges when everything is installed. Also, t-molding will interfere when putting the CP in place and will probably be more of a hassle than what its worth.
DNA Dan
« Reply #4 on: March 29, 2011, 03:09:44 pm »
Yea, I dont' think it would look good either to see the color there when you view the cab from the side. My dilemma is I am unsure how fragile the edge is going to be. I plan on laminating 5/8" particleboard with Wilsonart laminate. I mean is that stuff easy to chip putting the CP on and off over the long term? Perhaps I can protect that edge with a piece of felt strip so the CP is sitting cozy?
I plan on using 4 latch clamps to secure the CP from underneath. I read about the velcro method but prefer to not go this route.
grasspuddle
« Reply #5 on: March 29, 2011, 04:10:57 pm »
Haven't built my CP yet, so take this with a grain of salt.
I am going to build the pedestal by itself with 3/4" MDF. I am going to put a single panel of MDF on the top of it. Then the CP will go on top as its own contained box. I will drill 4 holes between them and attach carriage bolts as an easy(ish) connect/disconnect.
I got this idea from the famous Mamestrosity:
http://bellsouthpwp.net/d/d/ddilday13/home.html
He has photos of the pedestal by itself then shows the CP box with the carriage bolts attached. I think you're doing an upright cabinet, but the theory should still work.
Are you planning on moving this thing through doorways a lot?
DNA Dan
« Reply #6 on: March 29, 2011, 05:01:32 pm »
That's an excellent idea! Thanks!
I was thinking of doing my lamination work prior to assembly of the pieces, so I didn't think about adding a piece of wood there. That's great. This will further be strenthened by the face plate below the CP.
I will probably just laminate the interior part, or just the internal edge where the reveal will be. I don't plan on moving this a lot, but I would like options if I NEED to get it moved somewhere.
