Author Topic: K7000 Cap kit now now no neck glow dead?  (Read 3385 times)
epic69
  • Last login:October 21, 2011, 04:21:03 pm
« on: March 22, 2011, 11:52:29 pm »
I have a k7000 25" monitor that was dim most of time and was in need of a cap kit. i finally got around to doing a cap kit on this chassis. Now i have the cap kit installed and verified all caps are correctly installed and reflowed all the existing solder joints because i know these k7000 are known for cracked solder joints. I installed the chassis back into the cabinet and attachd the anode cap. Now i have no neck glow and no picture at all. I doulbe checked all caps are correctly installled. What would you check next? If i cannot get this to work where can i send this chassis to have someone fix it for me? Thanks for any response!
Kevin Mullins
    • Me on Myspace
Re: K7000 Cap kit now now no neck glow dead?
« Reply #1 on: March 23, 2011, 05:37:04 pm »
Do you hear a quick burst of HV static when you first turn it on ?
Have you checked the B+ voltage ?
(it may be high and going into shutdown)
Even though you checked solder joints..... double check EVERY large resistor again. There are a couple spots that will crack the trace near the joint that will kill the heater voltage, hence no neck glow.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #2 on: March 24, 2011, 10:15:21 am »
If the tube filament is glowing then the horiz section is running fine.....the filament runs off the flyback.
Did you cut/remove any wires when you did the cap job? 'specially the gnd wire that ties to the neck board and the tube dag.
epic69
« Reply #3 on: April 01, 2011, 09:33:59 am »
Yes i cut a gray wire that i assume is a ground, but i did connect it back when i put the chassis back in the cabinet. I just twised the wire strands together but that should be sufficient ? correct?
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« Reply #4 on: April 06, 2011, 05:52:13 pm »
Make sure this wire is connected and making a GOOD connection:
