February 03, 2026, 10:37:21 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Main Forum
Problems with mame scanlines after upgrade
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Problems with mame scanlines after upgrade (Read 2218 times)
notroubleclubber
Trade Count:
0
Full Member
Offline
Last login:October 07, 2023, 04:26:25 pm
on:
March 22, 2011, 03:49:16 pm »
I am using mame 0139 and previously used the scanlines.png which worked well with my inboard intel graphics and pc monitor. However I decided to upgrade the graphics to a ati radeon 512mb pci express.
Now it all runs brilliant apart from mame now doesn't show the scanlines.
The configuration is still the same so what is the problem?
Last Edit: March 22, 2011, 04:19:00 pm by notroubleclubber
Logged
notroubleclubber
Trade Count:
0
Full Member
Offline
Re: Problems with mame scanlines after upgrade
Reply #1 on:
March 23, 2011, 04:02:16 am »
any ideas?
Logged
VanillaGorilla
Trade Count:
0
Full Member
Offline
Last login:March 08, 2019, 10:23:51 pm
Coin detected in pocket
Reply #2 on:
March 23, 2011, 11:55:12 am »
If you switch back to the on-board intel graphics, do the scan lines return?
There is no reason I am aware of that a video card would impact the scan line overlay. Are the png's in your /artwork folder? Can you post the relevant portion of your config.ini file?
Logged
http://forum.arcadecontrols.com/index.php?topic=109040.0
- Taito Wide-Body Classic
notroubleclubber
Trade Count:
0
Full Member
Offline
Reply #3 on:
March 23, 2011, 12:54:01 pm »
the config hasnt changed between me using the onboard video and the new grafix card.
Im guessing its because the resolution is different with this new card as the screen seems "bigger" and as i was using scanlinesbg.png or something it was only just noticable using the on board grafix so im wondering if i cant see it now because the resolution is slightly different.
Im going to try and change what png i use to see if that has any effect.
Thanks for the reply.
Logged
Gray_Area
-Banned-
Trade Count:
+1
Full Member
Offline
Last login:June 23, 2013, 06:52:30 pm
-Banned-
Reply #4 on:
March 23, 2011, 09:10:06 pm »
Try re-setting the effects in the Advanced tab. Then re-select your desired effect. If that doesn't work, try a fresh directory of MAME.
Logged
-Banned-
notroubleclubber
Trade Count:
0
Full Member
Offline
Reply #5 on:
March 25, 2011, 05:03:27 pm »
What advanced tab. Im using command line version of mame 0139
Logged
Gray_Area
-Banned-
Trade Count:
+1
Full Member
Offline
-Banned-
Reply #6 on:
March 27, 2011, 01:47:49 am »
Hah, yeah, I was thinking MameUI. If you don't know your way around an ini, then use UI.
Logged
-Banned-
notroubleclubber
Trade Count:
0
Full Member
Offline
Reply #7 on:
March 27, 2011, 03:12:29 am »
Had a go at changing the scanlines type today and found one that wasagood effect.not entirely original but it does work and to the untrained eye looks fine.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
