Author Topic: ok, mame question here  (Read 2291 times)
NipRing
  • Last login:January 11, 2026, 10:31:53 pm
  • I love cats but i just cant eat a whole one myself
« on: March 18, 2011, 06:48:31 pm »
I have an aimtrak, turbotwist 2, and a trackball all hooked up. I know how to correctly set up each divice in mame. For example i'll set up the aimtrak gun under tab/player one settings/ x axis and y axis it will show as  lets say mouse 3. It will work great no problems. Same for spinner (mouse 4)and trackball (mouse 5). But after i shut down and reboot each device comes up as a different mouse "number". Like i had the gun first set up and mame told me it was mouse 3, but after a restart the gun wont work unless i do the setup again and now it tells me the gun is mouse 5... :dizzy:. I'm not unplugging and switching around usb plugs either. How can i keep them from changing mouse id numbers? My setup is much less impressive if i have to set up my stuff each time i turn it on   :dunno
Bill
VanillaGorilla
  • Coin detected in pocket
Re: ok, mame question here
« Reply #1 on: March 19, 2011, 12:38:17 am »
are they in a hub, or dedicated ports on the pc itself?
NipRing
« Reply #2 on: March 19, 2011, 01:01:13 am »
I went out of my way to not use any hub. I have 6 ports on the motherboard and a pci card with 4 more ports.
johnd23
  • Last login:December 11, 2023, 12:57:59 am
« Reply #3 on: March 21, 2011, 02:07:04 am »
I am having the same problem with my aimtracks.. When I reboot usually 1 of the 2 guns will work in mame. I have to unplug all usb devices, plug in the 2 aimtracks first, then everything else. Doing that fixes the problem, but its annoying to do it every time i reboot. I have the 2 aimtracks configured in the aimtrack utility as device 1 and device 2. All my usb devices are connected to the motherboard.
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #4 on: March 30, 2011, 03:49:50 pm »
I was having the same usb issues with my 2x spinners, 2x aimtraks, and trackball, but drventure has made a program to help with usb devices being reassigned in mame.
There is supposed to be a way to setup mame with a device name but I can't seem to find it, so until then, I'll use this. IMHO the windows mame build should have the ability to "lock" a usb device to a monkier ie. "Mouse 3", but like I said I can't seem to find it.
http://forum.arcadecontrols.com/index.php?topic=108767.0
