Author Topic: ZSNESW startup static  (Read 1958 times)
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« on: August 25, 2003, 11:34:51 am »
I get a loud static sound burst when a ROM first loads up in ZSNESW.  Anyone know how to get rid of this?   Is it a directsound initialization "feature" in the windows port?
« Last Edit: August 25, 2003, 11:35:29 am by CM »
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re:ZSNESW startup static
« Reply #1 on: August 25, 2003, 12:45:06 pm »
What sound card are you using and did you change the default sound options?
No - you should not be having this prob.
You might look for an answer on zsnes boards
http://board.zsnes.com/phpBB2/viewforum.php?f=2&sid=d00f65f1cdd9801e2cff1cfefe4ee6c2
CM
« Reply #2 on: August 25, 2003, 02:22:20 pm »
I get this on 2 machines .. one with a SB Live and the other with generic onboard sound.   I haven't touched any sound options with ZSNESW.
I will also take a deeper look at the znes boards.
Aceldamor
« Reply #3 on: August 26, 2003, 06:27:30 pm »
I haven't had that problem and I am running a SB Live! card with Win XP....have you tried updating the drivers?
Fuzzy Wuzzy was a woman!
Minwah
    • MAMEWAH
« Reply #4 on: August 26, 2003, 07:04:58 pm »
Try reducing the volume setting slightly  ???
