Author Topic: Aimtrak Question  (Read 2222 times)
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
Aimtrak Question
« on: March 17, 2011, 04:50:50 pm »
Just picked up a few PS1 guns really cheap and would like to know if they are suitable to use with the aimtrak. Also would I need a USB adapter or does the aimtrak have its own cable. Here are the guns:
« Last Edit: March 18, 2011, 05:24:17 am by Termin8tor »
milhouse
  • Last login:March 02, 2023, 08:03:32 pm
Re: Aimtrak Question
« Reply #1 on: March 17, 2011, 04:55:11 pm »
They won't work.  You can gut the guns and install the AimTrak PCB in them, assuming the PCB will fit.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: March 17, 2011, 05:04:19 pm »
They will work with aimtraks.  The aimtraks come with their own usb connections.  You basically gut everything out of the gun except the trigger and buttons
Termin8tor
« Reply #3 on: March 17, 2011, 05:14:47 pm »
Excellant just the answer I was looking for. Does anyone know if I could still use the reload pedal.
Donkbaca
« Reply #4 on: March 17, 2011, 05:17:39 pm »
probably could.  You would have to extend a wire from the pcb, out the gun, to the pedal
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
« Reply #5 on: March 18, 2011, 12:58:40 am »
Using the pedal as is would be pretty impractical to try and piggy back off the aimtrack setup for a button. You'd be better off just hacking the pedal directly to the PC assigned as some other key.
So long as the pedal uses a switch of some type, wire that to a single Key stroke and in Mame assign that key as the reload, or "hide" or whatever button (should work I think).
I've modded the guns before, and I've created some more complicated pedals that use potentiometers, but for that I hacked a separate joystick.... so ... it can be done, it just depends on how much you want to customize things.
