Author Topic: 25/32" T-Molding?  (Read 966 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
25/32" T-Molding?
« on: March 10, 2011, 04:19:07 am »
I'm about to order some T-Molding for two control panels which are made out of laminated MDF. (The same material used on counter tops).
With the lamination the thickness is 25/32".
No one has this thickness and I was wondering if I should just get the next larger size which is 13/16" and use an Exacto blade to trim it, or should I get the next smaller size which is 3/4" and make sure I install it flush with the top of the control panels.
Either way the T-Molding available will be 1/32" over or 1/32" under.
Any suggestions?
Thanks.
Darren Harris
Staten Island, New York.
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
Re: 25/32" T-Molding?
« Reply #1 on: March 10, 2011, 07:54:51 am »
bigger and trim, if you think it needs it (1/32 aint much)
  • Last login:November 25, 2025, 07:49:55 pm
« Reply #2 on: March 10, 2011, 09:25:42 am »
bigger and let it overhang on the bottom 1/32"
« Reply #3 on: March 10, 2011, 09:30:05 am »
Bigger and let it over hang 1/64" on both sides, that's practically and RCH. If need be trim the top.
D_Harris
« Reply #4 on: March 10, 2011, 01:44:52 pm »
Thanks everyone.
That's what I figured.
Now does anyone know where I can find 13/16" green T-Molding? (I found the blue I need in that size at T-Molding.com).
Thanks.
Darren Harris
