Author Topic: Problem with 2 way games  (Read 1525 times)
danivempire
  • Last login:November 05, 2014, 01:50:57 pm
« on: March 03, 2011, 04:03:06 pm »
Hi all
Well, I got a hell of a problem...
I use 2 ultrastick 360 with malaFE, the way my panel is, I mounted the sticks on the wrong way (sorry, I don't know how to say it in English)
In fact, I didn't have the room to place them correctly so I had to turn them at 90 degrees, so the right is up, left is down etc etc...
Now of course I use the u360 plugin with malaFE, but with two directions games (wonderboy for example) I'm screwed...
Because it's loaded as a two way games I cannot re-map the left-right to my up-down sticks (I know, it's complicated)
I tried changing in the controls.ini to four ways, even deleting the info of the game but when I click the metadata the game is still in two ways ...
any idea how I can change the options???
thank you for reading this over-complicated issue...
PsychoMikey
Re: Problem with 2 way games
« Reply #1 on: March 03, 2011, 04:47:22 pm »
If i understand correctly the 2-way game loads your 2way map trough your mala plugin. At that point UltraMap uses your 2 way map.
On the backside of things, MAME loads the default MAMA 2way analog map. If your 2way U360 map in UltraMap is not setup correctly, it's impossible with your setup to use anything other then the range that the map allows. For example, after u load a 4way map it's impossible to use left/up, right/up, left/down en right/down because corner's are not allowed.
When the game is loaded in MAME use a keyboard to 'alt-tab'  out of mame an load UltraMap (run as administrator) and check which movements you can make with your sticks. If you can only move left and right, you won't be able to set up and down.
A simple fix could be to replace your UltraMap 2way map with your 4way/8way map. New versions of MAME use a analoge map them selfs, so mapping trough UltraMap is not really needed anymore.
You could also take a look at this:
http://www.headsoft.com.au/index.php?category=mame&page=joymap
You could use this to make special maps for mame. If it's just a single rom that gives the problem, create a map for that particular game.
If you need a fix for all 2way games,  make a working map and replace the default MAME map.
Don't know how big your space issue is under your CP but i would always try to remount the sticks the correct way. The top mounting plate can be mounted "landscape" or "portrait".
Sorry for the long story, hope this helps.
danivempire
« Reply #2 on: March 04, 2011, 05:09:19 am »
Thanks for your help ^^
I managed to find a way
I edited the controls.ini AND the mame.xml (didn't know that the metadata where in fact in that file). I changed the joy2way for this game to joy4way in both files, and now it runs fine.
Reminder for next time, make more room for the control panel to avoid this kind of problem and be able to put the joystick in the reight way  :whap
