Author Topic: Power Supply for Scratch Built Cab  (Read 1178 times)
Woodshop Flunky
« on: February 22, 2011, 09:38:14 pm »
A while back I read an article about building a MAME brain:  http://www.retrothing.com/2008/03/diy-build-a-mam.html
I've decided to build my arcade cabinet with a new motherboard: http://www.amazon.com/Intel-Innovation-Motherboard-Dual-Core-BOXD525MW/dp/B0041RSC94/ref=sr_1_1?s=electronics&ie=UTF8&qid=1298428234&sr=1-1
Also, I've decided to pick up the following LED matrix from Groovy Game Gear: http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=83&products_id=307
The rest of the build will include the usual suspects: 1 joystick, 1 spinner, 6-9 pushbuttons, and a J-PAC board
The monitor will be plugged into a power strip mounted inside the cab.
Okay, here's the question.  What type of power supply would you guys recomend for this type of configuration?  I've noticed several different power supplies on sites like Groovy and Arcade Emulators.  Would those be sufficient?  Or would it be better to get a PC power supply like: http://www.amazon.com/Coolmax-M-500B-Supply-Connectors-ATX12V/dp/B0013FIO04/ref=sr_1_4?s=electronics&ie=UTF8&qid=1298428617&sr=1-4
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Power Supply for Scratch Built Cab
« Reply #1 on: February 22, 2011, 09:49:39 pm »
If its gonna be a PC based machine, use  PC pwr supply.
BobA
  • What Me Worry?
« Reply #2 on: February 22, 2011, 10:52:20 pm »
If you do not use a PC type power supply your motherboard will not receive the signals it needs to turn on properly.
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #3 on: February 22, 2011, 11:29:47 pm »
Can a PC motherboard even operate with a source of power that it can't communicate with?
Woodshop Flunky
« Reply #4 on: February 22, 2011, 11:51:57 pm »
Well, that about sums it up. :)
I didn't realize the PC power supply provided anything other than juice.
