Author Topic: Shutting gens emulator down  (Read 5122 times)
fimbo1975
  • Last login:February 28, 2011, 08:25:59 am
« on: February 19, 2011, 09:58:56 am »
Hi does anyone know how to shut the gens megadrive emulator down the only way i can do it is with my mouse i cant find a way to do it with my arcade controls.
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
Re: Shutting gens emulator down
« Reply #1 on: February 19, 2011, 10:07:14 am »
Try Kega Fusion another emulator that emulates megadrive/genesis, 32x, megacd/segacd, master system...it's more up to date
fimbo1975
« Reply #2 on: February 20, 2011, 08:43:22 am »
looked at keg fusion but same problem is there no megadrive emulator which allows you to preset keys and also lets you preset the shutdown key.
Celsius
    • Rcade project
« Reply #3 on: February 21, 2011, 09:53:08 am »
i use autohotkey to redirect (to 1 certain button) all the different shutdown keys of all the different emulators and pc games
fimbo1975
« Reply #4 on: February 21, 2011, 02:38:47 pm »
Well i spent nearly two hours trying to figure out how to use the program mentioned above but its so confusing is there no megadrive emulator that has a key press to shutdown?
Sibby
  • Last login:April 17, 2011, 11:30:52 pm
« Reply #5 on: February 21, 2011, 03:51:56 pm »
I use Stella for my Atari 2600 emu.  I wanted to map ESC to close the emulator and there is no way to do this within the emulator itslef, so I setup Mala to do it.  Here's how.  Go to Other Emu Config > (select your emu) > Options tab > at the bottom check "Use Hotkeys" > Click Edit Hotkeys > Click the Add Button > Give it a name (like exit or shutdown) > For Type choose "Close" from the dropdown > Type the key you want to use in the source box (I pressed ESC) > Click OK and you're done.
Hopefully I understood your problem correctly. This hotkey essentially just kills the program, which is what you want.  If so that should do it for you.
Good luck!
fimbo1975
« Reply #6 on: February 22, 2011, 09:10:28 am »
Thanks sibby the information worked a treat it works everytime im now a happy bunny.
Thanks :notworthy:
