Author Topic: Hyperspin FE- I hear game wheel moving behind the game when playing MAME- HELP?  (Read 1713 times)
BigDaddyE
  • Last login:October 02, 2012, 01:52:48 pm
As I continue to learn about the Hyperspin platform and add or subtract to it, I recently added LEDBlinky (just to map u360's).
I have begun to work the kinks out, since nothing is ever quite as easy as plug and play with me, unfortunately.
So ever since I have applied LEDBlinky to the Hyperspin platform and start a game in MAME (don't have other's up quite yet), I can hear the game wheel turning behind the game being played, with the sound effects and all. This is pretty annoying.
Wondering if anyone has come across this issue and has a work around for it?
Let me know what other info is needed to further troubleshoot.
Thanks.
Eric
Someday this hobby will be easy for me!
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Have you tried the Hyperspin Forums? If this is something that's an issue with hyperspin they might also want to know so they can fix it in the upcoming release of the new version.
I've had similar issues with that, it always turned out that it was an issue in my hyperlaunch script. Did you ever have this issue before? or did you make changes to the hyperlaunch script before adding the led blinky?
-SS
BigDaddyE
I have placed the same message on the Hyperspin board. I usually get a couple of folks in here that help, not so much over there, usually.
I never touched the script, that is way above my head. I have never had this problem before, Blinky may not be the issue, I just noticed it now that I have Blinky on board.
Thanks for the help, I will hope others can give a suggestion or two!
Eric
