Author Topic: Rock-Ola 474 Sybaris : Replacement Connectors  (Read 2879 times)
bele2009
  • Newbie
  • Last login:February 21, 2011, 09:15:50 pm
« on: February 07, 2011, 10:23:08 pm »
Hello all
I'm restoring my first juke, a Rockola 474 Sybaris. The problem I have is that the connectors on most control boxes are extremely dry and the break as soon as I try to remove them to service the boxes. Not very practical indeed...
I spent quite some time yesterday on DigiKey trying to figure out the AMP part number to replace those connectors. Some of them are from the MATE-N-LOK family and I found a perfect match including the crimps. I plan to order those with a contact extraction tool and transfer the pins from the old housings to the new ones.
However I cannot locate the correct part for a few connectors. A 3-pin panel-mounted housing on the Animation Light Controller and a 21-pin on the Credit Unit. The 3-Pin as the number AMP 480758 but I cannot find anything with the part number. Any idea where I can get the proper replacement housings? If these are no longer available what you guys a doing when a connector is broken?
Thanks a lot,
Eric
