Author Topic: Poor Video Refresh - Yuck!  (Read 1422 times)
Woodshop Flunky
« on: February 05, 2011, 10:48:54 am »
I've got MAME running on an P3 with 512meg running XP.  I also have the same MAME setup running on a Core 2 Duo with 4gig running Windows 7.
I'm using a CRT VGA monitor rotated vertically.
The problem I'm noticing (on both setups) is that some games like Xevious and Twin Cobra seem to have a "shift" in the graphics that kind of scrolls across the screen.  It's kind of like looking at the monitor through the blades of a fan, but not nearly so pronounced.
Is this to do with the games originally being developed for 15Khz monitors, and I'm using a multi-scan monitor running at a higher resolution and scan rate?
Or is there some other issue.  I've only noticed it on scrolling games.
Any ideas?
MonMotha
Re: Poor Video Refresh - Yuck!
« Reply #1 on: February 05, 2011, 11:00:15 am »
This sounds like "tearing".  Check that you have vsync or triple buffering turned on in your emulator.
  • Last login:Today at 11:45:41 am
« Reply #2 on: February 05, 2011, 02:30:19 pm »
v-sync. nuff said.
:if nuff said=0 then
The artifact occurs when the video feed sent to the device isn't in sync with the display's refresh, be it due to non-matching refresh rates, or simply lack of sync between the two. During video motion, screen tearing creates a torn look as edges of objects (such as a wall or a tree) fail to line up.
During the vertical blanking interval, the driver would order the video card to either rapidly copy the off-screen graphics area into the active display area (double buffering), or treat both memory areas as displayable, and simply switch back and forth between them (page flipping).
Woodshop Flunky
« Reply #3 on: February 05, 2011, 06:27:48 pm »
Yep!  That fixed it.  Looks great now!  I set waitvsync=1 and left syncrefresh=0 in the config file.
Thanks a ton!
