Author Topic: Can someone post a Gamelauncher Daphne.cfg  (Read 1210 times)
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« on: August 20, 2003, 10:37:58 am »
I'm looking for a daphne.cfg file for gamelauncher. Does anyone have one? Actually, the .rom and .map file would be appreciated too :)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:Can someone post a Gamelauncher Daphne.cfg
« Reply #1 on: August 20, 2003, 01:59:20 pm »
IIRC, I needed to specify the command line parameters for each game in daphne at the end of the cfg file - no big deal since there are only ~10.
An easy way to do it is to get each game working with the daphneloader, and have it show the commandline before starting the game.  Then just cut and past that to the end of daphne.cfg.
I would be wary of using someone else's cfg files, as they are usually tailored to that person's specific setup.  Might be more hassle than it's worth - and the rom and map files are easy to make (again, only about 10 games).
SpAwN
« Reply #2 on: August 20, 2003, 04:01:20 pm »
I found this site that gives a how to on setting up daphne with gamelauncher
http://www.rsad.edu/~kosborn/gldaphne.htm
