Author Topic: Starting a new DK cab  (Read 6682 times)
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« on: February 01, 2011, 11:58:39 pm »
Off to a good start. 20" vertical LCD monitor, modified DK control panel, working coin door, running MALA. I got a coat of PVA primer on it today. I need to fit one more panel between the monitor and marquee light, then it should be ready for paint.
Erik
Re: Starting a new DK cab
« Reply #1 on: February 02, 2011, 08:29:56 am »
lookin nice!  going to be blue?
« Reply #2 on: February 02, 2011, 12:48:01 pm »
Any chance you can get a 19" CRT for proper 4:3? I just love a CRT for classics. It almost looks like the image is floating inside.
« Reply #3 on: February 02, 2011, 12:53:49 pm »
I'd like to try and do the same thing one day. I just bookmarked this project.
ghettodish
« Reply #4 on: February 02, 2011, 08:00:52 pm »
I skipped the CRT monitor on this build. Happ has a nice bezel for 20" LCDs. It turned out to be the exact width to fit my cab.
Today I fit the last needed panel, routed out the channel for the T-molding, and did some putty work. This was my my first time using PVA primer...it sands down pretty good despite its properties.
Next I'll tune up the bodywork a bit and start painting it the original colors. The only thing I gotta figure out is how to mount the main lexan bezel. I didn't have the bezel artwork printed yet. I might just spray paint for now. The whole thing needs to be a working unit for the Super Bowl party I'm bringing it to.
ghettodish
« Reply #5 on: February 02, 2011, 08:42:24 pm »
Here is my new CP layout. Centered the joystick and added a second jump/fire button. I have the vector for it if anyone needs it.
ghettodish
« Reply #6 on: February 03, 2011, 06:52:40 pm »
First coat of paint. I got the paint from Lowes after finding a formula for DK blue somewhere on this site. The black is a stock Kelly-Moore color, exterior semigloss Carbon. I added FlowTrol to the Carbon on the first coat to help it lay off better. It worked, but it also added a gray tinge to the paint. Final coats will be full strength, straight from the cans.
I followed the plans from jakobud.com
The plans didn't show how the monitor was mounted. I set it at a 45 degree angle. I took an educated guess at the height...I hope it works out ok after the front plexi is installed.
dandare
« Reply #7 on: February 03, 2011, 07:13:01 pm »
Looking good already, will look fantastic when finished!
britinva
  • Last login:April 04, 2011, 08:53:26 am
« Reply #8 on: February 03, 2011, 07:20:26 pm »
The blue really pops
Did you brush, roll or spray?
VanillaGorilla
  • Coin detected in pocket
« Reply #9 on: February 04, 2011, 02:43:08 am »
A 20" LCD @ 1600x1200 is an ideal 4:3 panel.
mgb
  • North East, US
« Reply #10 on: February 04, 2011, 09:04:28 am »
very nice  ;D
« Reply #11 on: February 04, 2011, 09:04:53 am »
FWIW, I read it as a 20" widescreen. I still prefer CRT's for classic video games, but proper 4:3 is even more important.
The happs bezel isn't a big deal if he was planning on using a DK artwork bezel. Taped black construction paper to the monitor works just fine (you can't even see it).
ghettodish
« Reply #12 on: February 04, 2011, 11:30:41 am »
The monitor is 20" 4:3. These are getting tough to find in my area. I found it on craigslist for $70 and had to drive an hour to pick it up. It works like new and is viewable at a 45 degree angle. The happ bezel was more of a fix to hide the bizarre monitor mount than for anything else. I don't think black paper would have done the job this time.
I rolled the paint on, then back-brushed it to knock down the orange peel. It layed-off good.
I used a 1/2 lambswool roller and 3" angled Purdy brush.
severdhed
  • RIP Dinosaur Hippo
« Reply #13 on: February 04, 2011, 11:36:57 am »
looking good
ghettodish
« Reply #14 on: February 08, 2011, 01:50:17 am »
Got it mostly done it time for the Super Bowl party. It was a big hit. I still need to install the side art and monitor plexi. The picture doesn't show it, but the marquee really looks great in person.
2 people at the party are giving me deposits soon for their own cabinets.
VanillaGorilla
« Reply #15 on: February 08, 2011, 05:13:29 pm »
Spoken like a true painter!
ghettodish
« Reply #16 on: February 11, 2011, 12:56:09 pm »
Thanks, bro....what gave it away?  :D
Donkey_Kong
    • CNC Machines
« Reply #17 on: February 11, 2011, 07:31:20 pm »
Nice! I like the lit speakers too. Hmm you got the little wheels spinnin in that thick skull of mine now...   :cheers:
VanillaGorilla
« Reply #18 on: February 12, 2011, 10:39:48 pm »
The phrase "It laid off good." , and that you felt the need to identify the Purdy brush. Purdy is like the Snap-On of paintbrushes. You typically only learn that in a trade...And yes, in another lifetime I was a body-man/mechanic, and for a stint of a few years I did a lot of rehab & construction. So I've owned nothing but Purdy brushes since  ;D ;D
ghettodish
« Reply #19 on: February 13, 2011, 06:38:44 am »
The speakers came from Kragen/O'reily and are made by Dual. They come with the blue leds built-in and cost about $40. The ones I used are model TS45, 4", but they come in several larger sizes. I had to supply 12 volts to them for the leds to work. Here is a link to the Dual site:
http://www.dualav.com/mobileaudio/ts.php
ghettodish
« Reply #20 on: February 13, 2011, 06:43:24 am »
« Last Edit: February 27, 2011, 12:05:12 am by ghettodish »
ghettodish
« Reply #21 on: February 27, 2011, 12:00:59 am »
I think the Dual light-up speakers have been discontinued. I went to buy more and I ended up going to 4 stores before getting the last pair in my county.
« Last Edit: February 27, 2011, 12:03:54 am by ghettodish »
