Author Topic: MAXIMUS ARCADE 2.10 Usb gamepad recognition buttons problem  (Read 9165 times)
pike_
  • Last login:February 04, 2011, 10:03:25 am
« on: February 01, 2011, 04:16:41 am »
Hello everyone CONGRATULATIONS AND KEEP WORKING THE GOOD JOB FOR THIS WONDERFULL FORUM!!!!!!!!!! I am having problems with the maximus arcade 2.10.I used for my arcade 2 usb gamepads (speedlink and hornet i think???).The problem that i have is when i am to the preferences->controller setting-> View menu,although i have the 2 gamepads connected to my pc when i move the first joypad or press any single button i see activity on the joy1 icon.When i move or press any single button on the second joypad,i see activity AGAIN to the joy1 ICON!!!!!!!!.Why is this happening???I forgot to mention you that when i play games,the 2 gamepads corresponds to each player correctly.
(I want to use both gamepads to Maximus because i want to have buttons to control the setting that i am going to make.....(exit,previous menus etc)).
Thanks in advance Panagiotis.
pike_
Re: MAXIMUS ARCADE 2.10 Usb gamepad recognition buttons problem
« Reply #1 on: February 02, 2011, 03:15:39 am »
at least please someone tell me if it is happenning to you.....
BobA
  • What Me Worry?
« Reply #2 on: February 07, 2011, 12:24:14 pm »
Looking at the joystick setup for the interface I do not see a joystick number so the buttons probably respond to either joy.  Just as guess as I do not have joys connected.
Junix
  • Last login:March 31, 2021, 01:23:31 am
« Reply #3 on: September 14, 2011, 09:35:26 pm »
Hi,
Right now I have the same problem!
I have two usb gamepads connected:
http://img707.imageshack.us/img707/113/selection001cy.png
When I run Mame, everything is ok, I can use both of joysticks normally, but in MA I have the same problem that pike.
Any help is welcome.
BR,
Junix
« Last Edit: September 14, 2011, 09:38:36 pm by Junix »
BobA
  • What Me Worry?
« Reply #4 on: September 30, 2011, 12:18:26 pm »
I don't think it is a problem with Maximus as both pads will operate the maxims from the settings in setup 1 setup2 and menu but are OK in MAME and other emulators.  I have 2 pads now connected to one machine and since I do not need any more buttons for the maximus interface it is OK that joypad2 is not separately identified.  ;)
