Author Topic: Jamma Plus to Mame Conversion  (Read 2692 times)
coliveira
  • Last login:December 24, 2011, 03:39:17 pm
« on: January 26, 2011, 09:52:15 am »
Hello
First of all, I'd like to mention that this appears in the Miscellaneous Arcade section as well.  It seems like it may be a better fit here though.  Not sure which section is more appropriate.  Please let me know and I'll remove the other.
Anyway, I'm hoping to convert an Ultimate Mortal Kombat 3 machine to Mame for my nephews.  However, I plan on holding onto the board so that I can convert it back after they are grown.  Basically, I don't want to damage the integrity of the machine.
I think I have a very simple solution for the power, but I would like to confirm it before I screw anything up.  Would it be possible to disconnect the switching power supply (it currently is running at approx. 130 AC volts) and run a power strip into that wire?  From there I could plug the computer in and leave the rest of the power wiring in the machine alone?  When I'm ready to convert it back to Ultimate MK3 I would then replace the wiring from the power strip back to the switching power supply.  Would this be feasible and not destroy anything?
Thank you in advance and I promise that it is not my intention to simply gut the machine.
Chris
Re: Jamma Plus to Mame Conversion
« Reply #1 on: January 26, 2011, 01:53:57 pm »
Yeah, this is the wrong forum for this. You were correct in the first place posting it in Misc.
