Author Topic: Dual Trackball in MAME; How do I do this?  (Read 1840 times)
goldenageofarcade
  • Last login:February 02, 2014, 04:46:46 pm
« on: January 26, 2011, 02:03:01 am »
Hi,
I'm hoping to find out how to make 2 trackballs work in MAME.  Is this dependant on the version of MAME?  Or the OS?  Or is there a gadget that allows for it?  I really want to make a Marble Madness control panel for my machine, and hopefully without updating my rig (running Win2K with whatever version of MAME was out circa 2003).
Any advice would be greatly appreciated!!
Regards,
Ryan
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
Re: Dual Trackball in MAME; How do I do this?
« Reply #1 on: January 26, 2011, 02:44:18 am »
im not the most knowledgeable on the subject, but i think i did this once by configuring 2 Mice as mouse X and mouse Y.
so you would need 2 trackballs wired and configured as mice. Like with 2 special USB trackballs, or with a normal trackball and optipac
goldenageofarcade
« Reply #2 on: January 26, 2011, 11:53:34 am »
Yeah, they'd be mice, but the problem is, or I should say, was (at the time I built my cab) is that for some reason, only 1 mouse could be recognized at a time, if you plugged 2 to the same machine, both would control the same thing, there was no way to make them control independantly from each other.  It seems that this is no longer the case, though I'm not sure if it's because Windows now allows it, or if there's a MAME version that allows it, or some other factor that makes this possible.
Hoopz
  • Last login:November 27, 2025, 08:22:44 am
  • Intellivision Rocks!
« Reply #3 on: January 26, 2011, 12:01:35 pm »
You'll need a newer version of mame to have to trackballs attached.  Multiple mice was added in 2006.
http://forum.arcadecontrols.com/index.php?topic=51327.0
Derrick Renaud
  • Last login:December 06, 2024, 04:31:44 pm
« Reply #4 on: January 26, 2011, 12:58:33 pm »
Also IIRC it is impossible on Win2K.  You need at least XP or Server2003.
http://www.urebelscum.speedhost.com/faqs.html#win2000limit
Also see the requirements at the bottom of this page:
http://msdn.microsoft.com/en-us/library/ms645565(v=vs.85).aspx
goldenageofarcade
« Reply #5 on: January 26, 2011, 12:59:40 pm »
Very cool, thanks for that info!  I don't know if Marble Madness is enough to warrant me essentially starting from scratch again, tracking down or updating ROMS, re-learning how to configure everything, etc, but at least I know what it will take if I do opt to go that route.
Much appreciated!
