Author Topic: What LCD Monitor for 60in1  (Read 1463 times)
woolley
  • Last login:February 15, 2022, 10:35:52 am
« on: January 25, 2011, 08:49:57 pm »
I'm building a 60in1 cabinet and I'd like to replace the monitor with an LCD.  Am I correct that they just plug into the VGA input on the 60in 1 board?  Also, since most of the 19" monitor have a 5:4 aspect ratio, will the games display correctly or should I spend a little more and buy one that has 4:3 aspect ratio?
Blanka
Re: What LCD Monitor for 60in1
« Reply #1 on: January 26, 2011, 03:46:41 am »
Check whether the resolution/refresh rate is supported. Otherwise you might need a separate upscaler box.
woolley
« Reply #2 on: January 26, 2011, 07:18:13 am »
How do you know what refresh rates are supported by the game.  I searched a lot and found a thread addressing this and I think I am going to order the HP LP2065.  It seems that everybody loves this monitor.  Now I just hope that I can make or modify a bezel to fit.
« Reply #3 on: January 26, 2011, 01:47:04 pm »
maws. Has resolution and refresh rates listed for every game.
