Author Topic: Disable 640x480 warning in XP?  (Read 3025 times)
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« on: August 19, 2003, 08:31:53 pm »
I've decided to try using Windows XP in my next cab, but I've run into one minor annoyance I can't work around.
I'm running in 640x480 because I've got a WG D9200 arcade monitor, but XP insists on warning me at every boot that my screen is set to a low resolution.
Anyone know of a way to disable this warning?
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
helios
  • Last login:September 08, 2005, 03:42:27 am
  • I'm a Moose!
Re:Disable 640x480 warning in XP?
« Reply #1 on: August 19, 2003, 08:48:58 pm »
Here is something I found that should disable that popup from coming up:
1. Click Start, click Run, type regedit, and then press ENTER.
2. Navigate to the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
3. Right-click the right pane, create a new DWORD value, and then name it EnableBalloonTips.
4. Double-click this new entry, and then give it a hexadecimal value of 0.
5. Quit regedit. Log off Windows, and then log back on.
These steps disable all Notification Area balloon tips for this user. Hope that works!
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #2 on: August 19, 2003, 09:43:26 pm »
I'm running 640x480 on a TV w/ XP Prof and I have yet to see this warning...crazy!  It must be the ATI drivers that disable it.
I hope you can solve your problem.  XP may be a fickle beast at times, but once you get it running on your cab, you won't be sorry.
« Last Edit: August 19, 2003, 09:43:52 pm by TalkingOctopus »
KevSteele
« Reply #3 on: August 19, 2003, 10:43:54 pm »
Helios:
Thanks -- I'll give that a try (I'm not certain I want to give up all notifications, but I think perhaps it might be wise to do it anyway on a cab.)
Octopus:
I'm running ATI drivers as well (the ArcadeVGA is a modified Raedon 7000), but still get the notification.
Perhaps it's because your TV is going through a TV-out port that XP is smart enough (barely) to realize that you need a 640x480 display!
I'll test things out and let you know how it goes.
Kevin
Minwah
    • MAMEWAH
« Reply #4 on: August 20, 2003, 05:43:51 am »
FWIW I don't get this warning either (using AVGA or 'normal' Radeon)...not sure why  ???
Lilwolf
« Reply #5 on: August 20, 2003, 08:29:54 am »
Funny... I COULDNT get it to go into 640x480 at ALL!
I ended up having to tell XP that my monitor ONLY supported 640x480 (I switched between two monitors... very very annoying)...
I ended up scrapping it for 98SE.  I'm really not to sad about it.  The overhead doesn't seem to be all that useful.
KevSteele
« Reply #6 on: August 20, 2003, 09:58:56 am »
Lilwolf:
If you click on the "Advanced" button in the Adapter tab, you can make it switch to 640x480. I actually use MultiRes, which makes things easier when switching between resolutions.
UPDATE:
I tried the registry hack, and it worked fine -- no more pop up warning. I do get a little red icon with an X in it that shows up in the system tray, but it vanishes after about 10 seconds.
Kevin
