Author Topic: Unknown part on WG K7000 chassis...  (Read 6728 times)
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« on: January 24, 2011, 11:37:45 pm »
Checking out a WG K7000 series chassis for adidas1984x who bought it complete with a tube, but it had a crushed remote board.  Since I have heard you shouldn't try to power one on with a remote board removed, I figured it would be a bad idea also to do it with one as bad as his was (all pots were destroyed!).  So he sent it to me to check on one of my tubes (while he waits on Bob Roberts to ship him a replacement) since I had a K7000 series remote board I could swap to it for testing.
Well, after reflowing some bad joints and checking over the chassis, I just don't know what the black box in the pic is for.  Can you guys enlighten me?  It has a heavy gauge red wire going to the anode cap (along with wire from flyback) and a lighter gauge black wire from the black box to the metal plate the HOT's heat is dissipated to.  Here it is:
Unknown part:
His damaged remote board...ARGH!!!
  • Last login:Yesterday at 12:34:05 am
Re: Unknown part on WG K7000 chassis...
« Reply #1 on: January 25, 2011, 11:17:01 am »
i've never seen that in my life before... does it just have the 2 wires or does it have a grounding tab that connects when you screw it down someplace? of course google doesn't turn up anything, although the # is similar to the flyback# for the WG... 046X0560-003
maybe it's dumping voltage from the anode... maybe an automatic tube discharger? maybe it's a voltage doubler...  :dunno
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #2 on: January 25, 2011, 11:22:53 am »
I think you're right about the discharger:
Next will be making new safety bleeder boxes to spec for some of the larger screen rasters found on 7600 39" & some u5000's.. While I know the demand for those will be short it will be settling to know they will soon be avail.
wells part # 046x0560-003
Kevin Mullins
    • Me on Myspace
« Reply #3 on: January 25, 2011, 07:16:25 pm »
That black box is pretty much a large capacitor with a grounding lead.
Helps to quickly bleed off excess HV when the screen flashes, namely from gun games and such.
Replacement flybacks will not have those.
I have never had any trouble running gun games without one, but that seems to be what those were most commonly found in. (as far as I have ever seen)
Might be other games that have some form of extreme "flashing" that goes on, dunno.
« Last Edit: January 25, 2011, 07:19:10 pm by Kevin Mullins »
WhereEaglesDare
    • My HomePage
« Reply #4 on: January 25, 2011, 07:59:43 pm »
Dont worry, Hes getting a fixed remote board...  I got the board right now, waiting on parts...
MKFan4Life
« Reply #5 on: January 25, 2011, 08:17:27 pm »
Thanks for the info guys.
  lilshawn, there is only two mounting spots made from the plastic on the casing.  Not sure exactly where this mounted on his monitor as it was loose as pictured when it shipped to me, but definitely no grounding tabs.  Just the two wires pictured.
cotmm68030, very similar part #, but the funny thing is, this came from a much smaller 25" tube supposedly.  Not a large one like the 39" model in your quoted text.  Guess they made them for smaller ones too.
Kevin, thanks for the identification.  I don't think he's putting this back into a gun game, although we just got a different chassis going for his Area 51 cab.  He wants to do a flyback and cap-kit install, but i am not sure I have the time for it at the moment.  Just trying to see if it works as is with a good remote board.  Somebody has already installed a few new caps, but not a complete kit it appears.
WhereEaglesDare, oh, I didn't know he was getting the old one fixed by you.  He told me he ordered a complete remote board from Bob Roberts?  I saw Bob had a complete pot replacement kit for the remote circuit board for $12, but guess he wants a backup.
WhereEaglesDare
    • My HomePage
« Reply #6 on: January 25, 2011, 08:50:07 pm »
Well hell if that is the case I'll just paypal him the 12 bucks and be done with it
« Last Edit: January 25, 2011, 08:56:45 pm by WhereEaglesDare »
Kevin Mullins
    • Me on Myspace
« Reply #7 on: January 25, 2011, 09:28:43 pm »
It typically mounts to the frame rail just above the flyback.
That smaller black wire is the grounding lead, it typically just gets tucked under one of the screws that mount the block to the frame.
Can't get to one of mine right now, so I just nabbed a pic of the net to kinda show you where it would be mounted.
MKFan4Life
« Reply #8 on: January 25, 2011, 10:16:32 pm »
Well, the $12 kit has 6 pots to solder back into a remote board, but he claims on his site that he occasionally comes across K7000 remote boards and rebuilds and tests them to resell for $20 for the complete board.  I THINK he told me he ordered a complete board from Bob, but I could have misunderstood, or he simply wants someone to rebuild the old one to have as a backup in the future.
Ken Layton
  • Guru
  • Technician
« Reply #9 on: January 25, 2011, 11:05:16 pm »
Chad at arcadecup.com sells brand new complete k7000 remote boards.
WhereEaglesDare
    • My HomePage
« Reply #10 on: January 25, 2011, 11:08:04 pm »
Yea I contacted him and he never got back to me, but the Bob Roberts got back at me very quickly.
MKFan4Life
« Reply #11 on: January 25, 2011, 11:33:58 pm »
You know the price, for future reference?
Kevin Mullins
    • Me on Myspace
« Reply #12 on: January 29, 2011, 06:28:10 pm »
P632/P802 Remote Board
$17.50
(+ shipping of course)
MKFan4Life
« Reply #13 on: January 29, 2011, 07:25:18 pm »
$17.50
That's a very good price.
WhereEaglesDare
    • My HomePage
« Reply #14 on: January 30, 2011, 09:53:06 pm »
Bob has them for 15 plus 7 shipping.
Im getting Justin a complete one from Bob, should have it in a couple of days.
MKFan4Life
« Reply #15 on: January 31, 2011, 05:31:27 pm »
[/quote]
Cool.  USPS site shows the chassis made it back to him today around 1pm.  He should have it going when he gets the remote board then.
WhereEaglesDare
    • My HomePage
« Reply #16 on: February 02, 2011, 08:51:25 pm »
[/quote]
He shipped the chassis off to get recapped?
Hell If I knew he was going to do that I would have recapped it before I sold it to him.
MKFan4Life
« Reply #17 on: February 02, 2011, 10:20:18 pm »
[/quote]
?  Ok.  Now I am getting confused here.  You are the seller of the K7000 series chassis to Adidas?  I didn't infer that from the posts in this thread.  He just told me he bought a monitor from someone and sent me some pics of it 'cause we have dealt with each other in the past concerning another chassis I capped and installed a flyback into.
The remote board in the series of pics of the monitor had each pot damaged badly, so I told him to not power it on until he either got it repaired with all new pots, or got a replacement remote board.  Then I told him I had a K7000 series chassis with the same remote board, and he asked if I'd test it for him with my remote board.  He was glad to pay shipping both ways, and I tested it for him after making some minor solder joint repairs.  It appeared to be working just fine, so, although he wanted to recap it and install a flyback, I didn't have time right now, and it was working very well IMHO, so I packed her up and shipped her back to him with no charge for anything besides the return shipping he reimbursed me for.
I think at the time he shipped it to me he just wanted to be sure it was working before investing anything in the remote board repairs or purchase, although the entire trip cost him about $20 here and back, which could have bought the remote board.  Still awaiting his reply as to whether he got it all together and going yet.
« Reply #18 on: February 02, 2011, 10:41:01 pm »
A little late on this, but two days ago I powered on a 25K7191 with the remote board disconnected. When it powered on, the monitor had a thick green horizontal stripe across the middle. Realizing the remote board wasn't plugged in, I powered it down and connected the remote. The monitor is just fine, there seems to be no ill effects from my blunder.
MKFan4Life
« Reply #19 on: February 02, 2011, 10:44:44 pm »
I have read that it could either damage the chassis, or the chassis won't power on without it.  I haven't been brave or careless enough yet to try it out... but just give me time... lol!
WhereEaglesDare
    • My HomePage
« Reply #20 on: February 02, 2011, 11:01:24 pm »
Yea I sold it to him, told him it was a little dim when I used it last and may need to be recapped, I didnt know the board was broken, that is why I bought him a replacement.
He said he was gonna recap it himself.
Did you notice it was a little dim at all when you hooked it up?
MKFan4Life
« Reply #21 on: February 02, 2011, 11:08:56 pm »
Not really dim to me.  But the tube I have been using to test with has a very weak blue gun.  The Red and Green seemed just fine, and I adjusted the Blue gain up high temporarily to make sure I had blue output, and it seemed as good as the tube could do.  Here's the results:
WhereEaglesDare
    • My HomePage
« Reply #22 on: February 03, 2011, 12:19:06 am »
Indeed...
It played fine with the lights off but with the lights on it got to be a lil hard to see.
I would have kept it but I put a 27" TV in my MAME cab and Im happy with it and I don't need it.
MKFan4Life
« Reply #23 on: February 03, 2011, 12:58:46 am »
Indeed...
Tough to record arcade monitor output with the video mode on my little 3.2 Megapixel Nikon without dimming or turning off the lights.  The monitor showed up just fine in a fully-lit room in person (of course with low blue emissions since my tube has a bad blue gun).  Maybe the tube you had paired with the chassis had weak guns?  I rejuvenated the tube I tested the chassis on a while back, but the blue gun didn't improve, although the other 2 guns did.
