Author Topic: Horizontal Monitors and Vertical Games  (Read 2843 times)
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« on: January 17, 2011, 04:28:00 pm »
I use an Arcadevga card with a 27" monitor. and using the closest resolutions as possible to the original games I have the issue with vertical games
not showing everything as bottom or top is cut off. I was wondering what other people do with this situation and rotating my monitor isn't an option.
Keg
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Horizontal Monitors and Vertical Games
« Reply #1 on: January 17, 2011, 04:32:23 pm »
Is this before or after adjusting the vertical size?
Where the problem is happening will depend on if there is additional image that's 'stretched' past the edges of the screen by the vsize  being too large, or if there is simply no image there as being generated by mame itself.
goldenageofarcade
  • Last login:February 02, 2014, 04:46:46 pm
« Reply #2 on: January 17, 2011, 04:42:27 pm »
I had/have the same issue, I have a 25" horizontal and on some very games I lose part of some vertical game at the top and bottom.  In Pac Man, for example, I can't see the fruit at the bottom, or the words Score and High Score at the top.  This doesn't bother me much, so I haven't done anything about it.  In Tron, though, I lose a considerable bit of the screen, I can't see the bottom row in the tank-maze, or the bottom wall in the light cycle.  What I did for this was change the resolution using MAME32(right-click on the game and go into properties, then it's the Advanced tab I think), I just experimented until I found the best one.  After I did this, the settings stick when using regular MAME.  Unfortunately, changing this makes the game less sharp, so I had to try maybe 20 different resolutions before I found one that let me see the entire screen that wasn't really bad looking.
I had to do the same thing on another horizontal MAME I built, so I guess it's just a by-product of how many lines are available on the monitor?
kegger
« Reply #3 on: January 17, 2011, 06:27:15 pm »
Yea I know where the problem lies I just wanted to get a feel for what other people are doing for it, such as just setting another resolution for that game
 or just dealing with it as is. I could set the game for 640X480 and leaving it but hoping for another solution to present itself that I didn't think of.
Thanks   :cheers:
goldenageofarcade
« Reply #4 on: January 17, 2011, 07:13:50 pm »
I was seriously considering building a dedicated vertical MAME just to deal with this issue, but in the end, I guess I figured it was "ok" enough after changing the res of the games that were really bad.
I'm watching this thread, though, in case someone knows a better fix.
Regards,
Ryan
newmanfamilyvlogs
« Reply #5 on: January 17, 2011, 08:18:12 pm »
Most regular arcade monitors will show 288 lines before it has to go interlaced.
How much can you adjust the screen with the monitor vsize pot?
kegger
« Reply #6 on: January 17, 2011, 08:37:33 pm »
I have it adjusted so the screen takes up the whole foot print of the monitor.
Not sure if I can do anything else with it or I may have to play with the bezel
newmanfamilyvlogs
« Reply #7 on: January 17, 2011, 08:39:31 pm »
Have you tried shrinking it down while you have a tall game on screen? Different resolutions will need a little tweaking.
kegger
« Reply #8 on: January 18, 2011, 12:08:51 pm »
Did some tweaking like you suggested and played with centering and the borders, shrunk it down with some vertical games
and I'm happy to say it isn't bad at all now. Thanks for your suggestions and getting my lazy you know what, to break out
the control for the monitor and actually mounting it in a accessible place and taking the time to do what I should have done
a long time ago.
Thanks again
Keg   :cheers:
john_abey
  • Last login:September 07, 2011, 03:51:12 pm
« Reply #9 on: January 18, 2011, 10:24:24 pm »
I use the slider controls in mame to adjust the screen to fit my 25" polo
usually it ends up around 800 to 900 when starting at a 1.000 screen horiz stretch
