Author Topic: Problem with Jukebox  (Read 4711 times)
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« on: January 16, 2011, 01:28:56 pm »
Hi!  :)
I have problem with jukebox...
Now i have configured different emulator in the Mala front end and i configure different layout for different emulators in the options-gui-layout.
I activated the mp3 jukebox and i can listen and change songs from my list, but the problem is when i want go to other emulator or i return to jukebox, often the song does not stop   :(
MaLa BETA 1.739c
Thanks!!!
« Last Edit: January 18, 2011, 05:21:08 am by PaTrYcK »
loadman
    • MaLa
Re: Problem with Jukebox
« Reply #1 on: January 18, 2011, 03:58:57 am »
I will have a look this weekend
PaTrYcK
« Reply #2 on: January 18, 2011, 04:09:03 am »
GREAT LOADMAN!!!!  8)
loadman
    • MaLa
« Reply #3 on: January 22, 2011, 04:31:59 am »
I had a look a can see a couple of issues.
Still working on it
PaTrYcK
« Reply #4 on: January 22, 2011, 05:15:49 am »
Still working on it
You are the best  ;D
PaTrYcK
« Reply #5 on: January 30, 2011, 06:41:24 pm »
Hi, another similar problem is present with the music on screensaver, if the wav file is active it does not stop if i return in game...
Thanks  :cheers:
loadman
    • MaLa
« Reply #6 on: March 06, 2011, 04:43:27 am »
...back on this
PaTrYcK
« Reply #7 on: March 08, 2011, 08:57:18 am »
...no problem, thanks for you great job!  ;)
loadman
    • MaLa
« Reply #8 on: March 10, 2011, 07:53:53 pm »
It's a tricky one, may not be Mala itself but a bug in the Video engine. Either way I need to crack the pattern that triggers it innorder to avoid it
loadman
    • MaLa
« Reply #9 on: March 13, 2011, 12:47:22 am »
Can you please confirm you have the same problem with v1.74
PaTrYcK
« Reply #10 on: March 13, 2011, 01:50:46 am »
I try it  ;)
PaTrYcK
« Reply #11 on: March 13, 2011, 07:27:39 am »
I have the same problem with MALA 1.74,
this is the video of the problem (sorry for low resolution):
Here my mala folder test:
http://www.mediafire.com/?u3zx3puac9r6l85
The problem is the same, i start one music in jukeboxe layout, change emulator: i go to mame layout and the song continue, return to jukebox and the song is off...i start the song, return to mame and the song continue...ecc...
This problem is present only if i change emulator with hotkey
If i change the emulator with mouse all work fine...
« Last Edit: March 13, 2011, 07:41:36 am by PaTrYcK »
loadman
    • MaLa
« Reply #12 on: March 13, 2011, 06:13:06 pm »
Thanks for the extra info... That will help :-)
loadman
    • MaLa
« Reply #13 on: March 20, 2011, 03:43:11 am »
Yes
If fade in/out is enabled it is broken... ;D
You video and posting was very helpful.
As MaLa is now configurable there are a few bugs that don't reveal themselves unless you are configured a certain way.
loadman
    • MaLa
« Reply #14 on: March 20, 2011, 04:18:07 am »
OK I think I fixed this  :cheers:
Please confirm problem is fixed in latest beta (see the website) and also the following reported problem is gone
Hi, another similar problem is present with the music on screen saver, if the wav file is active it does not stop if i return in game...
If not I need more details about what you are doing exactly. I know it is painful but it pays off  ;D
PaTrYcK
« Reply #15 on: March 20, 2011, 10:25:00 am »
Yeh!!!!
Great Loadman, with Mala 1741 beta work fine!!!!
