Author Topic: how is a control panel layered??  (Read 3110 times)
jahilton2002
  • Last login:January 17, 2026, 05:34:53 pm
« on: January 11, 2011, 05:08:20 pm »
i've seen some cab with just a bit of mdf and art work on top.
but how are the ones with perspex on top made...... more so how is the t-moulding flush with the top of the perspex.............
and i know this is a real noobie question to ask..... be gentle  :angel:
mgb
  • North East, US
Re: how is a control panel layered??
« Reply #1 on: January 11, 2011, 05:53:03 pm »
Typically you would size the t-molding to fit it.
for instance if using 3/4" t-molding, you can build you cp top out of 5/8" mdf and then lay you graphics on that, and then cover it with a 1/8' thick acrylic to protect your graphics. The 5/8" mdf added to the 1/8" acrylic will equel the 3/4" of the t-molding.
you can also get other sizes of t-molding if needed. you also use a size that is wider than needed and then trim it to size.
jahilton2002
« Reply #2 on: January 11, 2011, 06:35:16 pm »
like this?
upprc04
  • Last login:October 31, 2024, 09:06:56 pm
« Reply #3 on: January 11, 2011, 06:56:58 pm »
The first case would be if the wood is 3/4" and the T-Molding is 3/4".  The second case is if the wood is 5/8" and the T-molding is still 3/4".
What have people done to hide the bottom if they end up with case one.  I thought I read some people just routed the edge on the bottom of the wood, so it will hide the bottom of the wood.  Anyone else have any other techniques?
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #4 on: January 11, 2011, 07:06:56 pm »
You put a bevel, or chamfer on the bottom.
mgb
  • North East, US
« Reply #5 on: January 11, 2011, 10:10:43 pm »
Remember, you can buy thicker t-molding also.
T-molding.com has it up to 1.5" thick (Limited colors though).
You can then trim it to fit
heres a discussion on it:
http://forum.arcadecontrols.com/index.php?topic=86699.0
« Reply #6 on: January 12, 2011, 06:02:32 pm »
You can also chamfer the edge of the plexiglass and polish it. You'll need to hold it down with some bolts to ensure no one snags it.
Donkbaca
« Reply #7 on: January 12, 2011, 06:03:21 pm »
You don't need to hold down the plexi with bolts, the buttons are usually enough to keep it in place.
« Reply #8 on: January 12, 2011, 07:53:19 pm »
Sometimes you do. Some pieces just won't lay flat. Thats why I did it and the reason I don't use plexi anymore.
mountain
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
« Reply #9 on: January 13, 2011, 06:39:52 am »
Here is a picture showing how I did mine with 3/4" material. Just imagine the 1/8" Plexi on top.
