Author Topic: unplugable usb controllers in arcade problem  (Read 2006 times)
animatorJustin
  • Last login:January 14, 2023, 11:09:32 pm
« on: January 10, 2011, 06:41:10 pm »
hey everyone, how do you get unplugable usb controllers to work with mame without screwing up the joystick numbering in mame? ie: i have controllers that i only wanna plug in when they are needed. but adding or removing them messes with my cp
its so frustrating  :banghead:
Dazz
  • HyperSpin Team
    • VPUniverse
Re: unplugable usb controllers in arcade problem
« Reply #1 on: January 10, 2011, 09:55:50 pm »
As far as I know you can't keep it from happening.  The ID's are assigned by Windows and each time you unplug/plug in the USB the ID can change.  I have not been able to find a way to keep it from happening, so I just keep all of my adapters plugged in so they don't change.
SavannahLion
« Reply #2 on: January 11, 2011, 10:40:49 am »
Isn't there a utility in the utility section that manages joy assignments?
loppydog
  • Last login:April 18, 2012, 02:51:39 pm
« Reply #3 on: January 11, 2011, 01:10:24 pm »
I use Devcon with scripting to enable/disable my USB devices....Works great!
http://support.microsoft.com/kb/311272
Hoopz
  • Intellivision Rocks!
« Reply #4 on: January 11, 2011, 01:35:08 pm »
A couple of options in this thread;
http://forum.arcadecontrols.com/index.php?topic=94419.msg993306#msg993306
It's too bad u_rebelscum hasn't been on in almost a year.  He would be the best resource for this question.
More possible solutions:
http://forum.arcadecontrols.com/index.php?topic=93837.0
loppydog
« Reply #5 on: January 11, 2011, 03:48:08 pm »
yeah, I have been through this whole ordeal as well. I have had NO luck changing device IDs, no matter what ID they had, it never changed the "order".  Hopefully you have better luck than I have had!
